1983 E250 Getaway Van
Old Apr 23, 2015 | 01:52 AM
  #31
fordman75's Avatar
fordman75
Originally Posted by 68Mercury250Ranger
if that is the correct shift indicator/steering column for your van someone may have put the 5.8 into it.
Echo Echo Echo Echo
The shift indicator in his 351 Powered donor is the standard C6 transmission shift indicator. What makes you think someone swapped the 351W into it?
Old Apr 23, 2015 | 02:00 AM
  #32
68Mercury250Ranger's Avatar
68Mercury250Ranger
my computer " adequate" skills took me to pg 1 instead of top of page 2.
OOPS.
Old Apr 24, 2015 | 01:13 PM
  #33
NFLDFORD's Avatar
NFLDFORD
if that is the correct shift indicator/steering column for your van someone may have put the 5.8 into it. I've been through a lot of vans and trucks and have never seen an AOD behind a 351W OEM. rare behind a carbed 302 even. have a roll under and take a pic of your trans pan
you could always do a VIN decode, there is one here somewhere . I have it saved in my favorites when somebody is trying to sell me a Ford that sounds fishy.
cheers
I looked at the transmission pans. The Donor is a 85 351 4brl c6 transmission
My getaway van is 83 302 AOD. Both are all original.
Old Apr 24, 2015 | 09:45 PM
  #34
Conanski's Avatar
Conanski
OK I have some pertinent input, DO NOT under any circumstances bolt that AOD and 351 together with the C6 flexplate or you will destroy the trans the first time it is fired. The C6 flexplate has too much front-back offset which pushes the TC back into the pump causing metal on metal grinding which sends shavings throughout the trans. Very BAD. To use this combo you need a flexplate from a mid '80's crown vic that had a 351/AOD combo, that is a 28oz 164 tooth flexplate.
Now.. the AOD isn't the most stout trans in the world and early versions like this were particularly weak, I suggest you install a shift kit to firm up the notoriously slushy shifts and also upgrade to a Lokar TV cable if your truck came with a linkage rod assembly. This TV adjustment controls line pressure in the trans and it is critical that it be set right to prevent clutches and bands from slipping.
I'd also caution against using the AOD at all if this truck has anything less than 3.55 gearing, 3.73 to 4.10 would be optimal considering the size and weight of this vehicle, higher(numerically lower) gearing puts too much load on the trans in OD and it just won't last very long.
Old Apr 25, 2015 | 10:22 AM
  #35
NFLDFORD's Avatar
NFLDFORD
None of this is good news. I already separated the 351 and C6 and I broke the transmission lines removing the 351 from the van.
Old Apr 25, 2015 | 10:36 AM
  #36
NFLDFORD's Avatar
NFLDFORD
The AOD is original in the Getaway Van behind the 302. The transmission was tight and smooth on the shiftfor 2 years touring Saskatchewan. I started in SK with 75000km and headed for Halifax. The engine and transmission ran perfect for 3000km. Through the mountains in northern Ontario, no problem.
Old Apr 25, 2015 | 11:55 AM
  #37
NFLDFORD's Avatar
NFLDFORD
Old Apr 25, 2015 | 12:07 PM
  #38
NFLDFORD's Avatar
NFLDFORD
[QUOTE=Conanski;15301958]OK I have some pertinent input, DO NOT under any circumstances bolt that AOD and 351 together with the C6 flexplate or you will destroy the trans the first time it is fired. The C6 flexplate has too much front-back offset which pushes the TC back into the pump causing metal on metal grinding which sends shavings throughout the trans. Very BAD. To use this combo you need a flexplate from a mid '80's crown vic that had a 351/AOD combo, that is a 28oz 164 tooth flexplate.
Can I use the flexplate from the 302 AOD setup? This is the original AOD Transmission and flexplate in the 83 E250 getaway van, bolting to the 351.
Old Apr 25, 2015 | 12:14 PM
  #39
NFLDFORD's Avatar
NFLDFORD
Thanks for joining this thread Conanski, your knowledge and input is a big help.
Thanks everyone, with your help I may be get this thing on the road again.
Old Apr 25, 2015 | 01:32 PM
  #40
Conanski's Avatar
Conanski
No.. wrong balance weight.
Old Apr 25, 2015 | 02:25 PM
  #41
fordman75's Avatar
fordman75
Thank you for warning him about the C6 flexplate. I knew that at one time but just forgot about it.
NFLDFORD RockAuto Parts Catalog Has the correct flexplate.
PIONEER brand Part # FRA205 - $40.79.
or an
ATP brand Part # Z105 - $41.79.
or if you want to find a Ford part the #'s are: C5AZ6375T or E0AZ6375A.
Old Apr 25, 2015 | 04:03 PM
  #42
NFLDFORD's Avatar
NFLDFORD
That is what I thought. I got a guy looking into an old LTD.
Old Apr 25, 2015 | 04:08 PM
  #43
NFLDFORD's Avatar
NFLDFORD
[QUOTE=fordman75;15303375]Thank you for warning him about the C6 flexplate. I knew that at one time but just forgot about it.
This is the reason I joined FTE I have forgotten so much.
My body reminded me, the last time I did this. I was 30 years younger and there was 6 of us LOL
Old Apr 25, 2015 | 06:58 PM
  #44
Conanski's Avatar
Conanski
BTW.. you can find the rear axle gearing by finding the axle code on the drivers door pillar calibration decal and then cross referencing that with charts found here or in the owners manual, post up what you find and I can help source the correct info. The link below is good for some trucks but may not be accurate for earlier or later trucks.
Ford Axle Code Chart - Ford-Trucks.com
Old Apr 25, 2015 | 09:15 PM
  #45
NFLDFORD's Avatar
NFLDFORD
[QUOTE=Conanski;15303890]BTW.. you can find the rear axle gearing by finding the axle code on the drivers door pillar calibration decal and then cross referencing that with charts found here or in the owners manual, post up what you find and I can help source the correct info. The link below is good for some trucks but may not be accurate for earlier or later trucks.
Ford Axle Codef Chart - Ford-Trucks.com[/QUOTE
The axel and AOD transmission are original in the Getaway Van so wouldn't they be ok with t h e 351 and proper flexplate?
