vapor lock?
Old Apr 19, 2015 | 10:24 PM
northalberta's Avatar
northalberta
vapor lock?
Hi, i drive an 06 f350 with a 6.0 diesel. My truck has quit on me twice in two months. It lost power then stalled and would not restart. I had just changed fuel filters but checked them anyway to see if they were plugged. They looked clean so i put them back in and the truck fired up. It ran good then two months later it did the same thing. I noticed i could not hear the fuel pump so i pulled the cap off if the top fuel filter to see if there was fuel in it, and heard air being sucked in (or pushed out?) as i loosened the cap. I put the cap back on then turned the key and i could hear the fuel pump working. I waited for glow plugs and it fired up.
Is my engine getting vapor locked, or sucking air? If so then why would it only happen every now and then instead of continuously?
Old Apr 19, 2015 | 10:29 PM
04badford's Avatar
04badford
Inspect the fill tube? has anybody ever dropped the tank for any reason there is a gasket on the top of the tank, Or the Water separator allen nut is not tight. Just a few Guess's
Old Apr 19, 2015 | 10:38 PM
northalberta
I will check out the water seperator. Im just not sure if it is sucking air in the lines is the problem or if its not venting. Im almost certain it was sucking air in as i loosened the top fuel filter cap. I dont no why that would be
Old Apr 19, 2015 | 10:45 PM
04badford's Avatar
04badford
Have you Installed the Blue Spring kit Yet ? may want to do a Fuel pressure test this would tell you where if any air is sux or pushing out , Bad news for the Injectors .
Old Apr 19, 2015 | 10:52 PM
northalberta
No i dont think it has a blue spring kit. I just had a dealership install the egr delete kit a month ago.
Old Apr 19, 2015 | 10:57 PM
04badford's Avatar
04badford
were you Over heating? did they get the Oil Cooler replaced as well?
Old Apr 19, 2015 | 11:03 PM
northalberta
It was never overheating. I got the delete kit put in because the egr cooler was starting to leak. Im not sure if the oil cooler was replaced. If its something required when installing the delete kit then im sure it was done. But im not having any trouble with it. The problem im having happened before and after the kit was installed
Old Apr 19, 2015 | 11:12 PM
04badford's Avatar
04badford
I hear ya , Double check the Fuel pressure also take a look at the fuel cap's o-ring top and the HFCM . you have the OEM filters in yea?
northalberta
Another thing i should add is that no coded are showing
Old Apr 19, 2015 | 11:20 PM
04badford's Avatar
04badford
Are you using any fuel additive like Howes, Diesel kleen, Stanadyne If your getting fuel at a Non high recover filling station chances are Algae growth has started in the HFCM , when you pulled the Lower HFCM filter what did you see ? are you pumping any Bio fuel?
Old Apr 19, 2015 | 11:29 PM
northalberta
No additives. I use the same fuel as everyone in town ( only one place ) and its used in most of the heavy equipment around here. Nobody else has problems with it. The top o ring was good. I havent pulled the bottom yet but will in the morning. Im wondering why pulling the top filter cap off would solve the problem though and the truck starts and runs fine?
Old Apr 19, 2015 | 11:39 PM
04badford's Avatar
04badford
It could be that it releases the pressure off the OEM spring making it go back to Normal thus the reason for the Blue Spring and better fuel Pressure.
Old Apr 20, 2015 | 02:37 AM
Yahiko's Avatar
Yahiko
Like all the others.I say check the fuel pressure first.
The next thing to check is the tank screen, So you will
have to get at the top of the tank and remove the sender.
Look at the screen and also see how the little nipple thing
on the pipe looks on the sender. It's a one way valve to let
any fuel that the pump sends back to the tank flow back in
without allowing air to come back into the pump. It should
be soft and not hard. If you find the screen plugged up then
you want to clean the tank out and get any gunk out of it.
Please post back what you find.
Sean
Old Apr 20, 2015 | 07:23 AM
69cj's Avatar
69cj
Also, are you using OEM filters and caps? Double check the lower O ring and make sure the cap is seated.
Old Apr 20, 2015 | 09:28 AM
northalberta
Ok thanks. Filters are factory from the dealership. I will get the fuel pressure tested. We have a fleet of ford trucks up here in the oil patch. I no all the gas jobs have venting problems due to the amount of mud we go through. I have a gut feeling the tank needs to be dropped but i will have it looked at by the local certified ford mechanic when hes back from holidays. Im gonna check bottom filter today and will post the problem once the mechanic has a go at it. Thanks
namnguye
Jan 11, 2019 03:22 PM
Totally Tuna
Nov 21, 2018 08:07 AM
spanky350
Mar 4, 2014 08:18 AM
hank89
May 13, 2013 04:05 PM
texasjack
Nov 22, 2010 10:57 AM
