Freezing Great White North......problem
We are in a deep freeze here in Canada (outhern Ontario). This has happen a couple of times.
Outside temp -25c (-12f).
Truck was plugged in all night.
After I started the truck and let it stand idle for 5min. I slowly drive away. First through town and the the hiway. When I released the go pedal the engine would drop to an idel and then would accelerate up 2 time as if I depressed the pedal. This happened 3 times this morning and the other 2 days.
I was watching the gauges while the accelerator jumped up and the oil temp would drop to 35 from 185 and back up a couple of times.
I got to work parked the truck useing my scangauge I pulled the code P0198. -(Faulty engine oil temp sensor)
Would I be ok in driving my 6.0 till it gor warmer? What should I do in the mean time? Or should I change the sensor now?
Thanks for any help.
Add Vref to the things you want to watch if you have room on your SGII.
When you loose the Vref power you no longer will have any throttle response.
So with it acting like you are revving it up there may be some screwy voltages.
Then again I could be way off the mark.
Sean
Sean
Just too cold to dig under the hook right now.
I am not doing any damage while I was am I?
Thanks for all the help and advice guys.
No my coolant temps are not high. On these freezing days the ECT is just under reaching 190.
Just seeing the EOT going waky.
It's good to see you back here John. I was actually just thinking about you not too long ago. Rakel now has the hots for any low mileage 2010 to 2012 Fusion or MKZ that she can get her hands on, preferably with the 3.5L V6.
Thanks Mike for your input.
You said if you unplug the ECT sensor don't you mean the EOT sensor?
Now because of the deep freeze we are under now. I have an issue of working in this cold. I need my truck (daily drive), besides the fan running high am I to warry about any other issues that it may cause. If I have to I will park the truck and see about making other arranements for a ride to work untill these temps (outside) get warmer.
