My 12v Diary
Old Mar 29, 2016 | 02:09 PM
  #31
03V10Excursion's Avatar
03V10Excursion
I think I'm just going to pick up some 1st gen mounts then. They have to be cheaper than the $350 the conversion shops want.
Old Mar 29, 2016 | 06:54 PM
  #32
Pele's Avatar
Pele
Originally Posted by gots_a_sol
My engine came from a 93, so I already had the 1st gen mounts. Anchor #2710 for new rubber pieces, about $15 per side (same side to side)
Hmm. I wonder if those will fit a newer block. That'll save me a load of cash... Which I'll blow on an Eaton Procision dual clutch trans instead of an Allison 1000.
Old Mar 29, 2016 | 09:32 PM
  #33
03V10Excursion
If I find them, I'll let you know! So far just searching around the net I haven't found anything more than the rubber part of the mount.
Old Mar 29, 2016 | 10:18 PM
  #34
03V10Excursion
I found part numbers, but they are no longer available it seems 04429079 and 04429078.
I'm going to check with the Dodge parts guys at work tomorrow.
Old Mar 31, 2016 | 08:35 PM
  #35
eternal_177's Avatar
eternal_177
You're not going wrong if you get the conversion mounts very easy to install, worth the money. I'm in Ohio and got mine in 3 days then about 2 hours to get it in the Ex.
Old Apr 4, 2016 | 01:13 AM
  #36
AllAboutDaZ's Avatar
AllAboutDaZ
Do all mounts require the trans to be moved back and drive shafts modified?
Old Apr 4, 2016 | 03:18 PM
  #37
eternal_177
I used a built 47rh and my ford transfer case. My rear drive shaft is about 3 or 4 inches too long but mine is an 04 Ex. I guess it depends on what transmission you are using.
Old Apr 4, 2016 | 03:45 PM
  #38
gots_a_sol's Avatar
gots_a_sol
I used an nv4500/ford case. Cross member stayed in the same spot but I had to drill new holes for the mount.
On mine I had to shorten the front shaft 2" and lengthen the rear driveshaft 2". The rear shaft from an extended cab, short bed powerstroke/auto/4wd super duty fit perfect.
Old May 4, 2016 | 08:14 PM
  #39
eternal_177
Test Drive
So I took her out on the road today and she ran great. I will be doing a build log as soon as I get everything together I just wanted to thank you guys for all the insight and knowledge that guided me through this awesome build. THANK YOU
Old May 22, 2016 | 12:58 AM
  #40
crazytwo's Avatar
crazytwo
I would love to do a swap in my 03 Excursion that has a V10. It's a 2wd that I bought for cheap.
LOP223
Engine Swaps
62
Sep 9, 2021 08:44 PM
Moes641ton
All Other Items for Sale
Apr 23, 2012 08:49 PM
ItsMREMT
Oct 13, 2011 08:14 PM
Sero390
Ford vs The Competition
55
Nov 17, 2010 07:08 AM
hank89
Dec 24, 2006 08:18 AM
