surges after cold start
Yesterday I unplugged the ICP and this is what happened when I started it:
This is the same surging that I get on cold starts, but it never does it for this long. I plugged the ICP back in and it started and drove perfectly the rest of the day. The ICP sensor was replaced a few months ago.
Any idea what might be going on?
Unfortunately, I can't offer whole lot here. I checked the Temp in Sacramento, CA and it was 79* so I wouldn't think it would be oil related unless you not using a quality 15/40.
I did do some digging around on other sites and found people with the same issue. Although there issues are temperature related.
A dealership replaced a Neutral Safety Switch which cured one guys issue. I'm still tying to wrap my head around that one.
Another changed the IDM which resolved it.
Another had a sticking EBPV.
So here are some suggestions:
Oil - Are you using a quality 15/40?
Has it been changed regularly?
Could you abscond a Scan Tool to monitor some parameters?
1. Select the parameters indicated from the Scan Tool parameter list and monitor while cranking engine.
Data List Monitoring Parameter:
V-PWR 10.5 VDC Minimum.
RPM 100 RPM Minimum (0 - CMP Suspect)
ICP 500 PSI or 3.4 MPAM Minimum
ICPv (KOEO) Spec 0.20v - 0.30v
FUEL PW: 1 MS - 6 MS ( <1 / >6 IDM Suspect)
V-PWR - If indicating a low voltage condition, check battery voltage, charging system or power and ground circuits to the PCM.
DC% - Cranking NTE 20% / 65% is Closed. (IPR Suspect)
2. RPM - Low RPM could be an indication of starting/ charging system problems
3. No RPM indicated with the engine cranking - could be CMP circuit fault, check for DTC’s.
4. ICP - A minimum of 500 PSI (3.4 mPa) is required before the injectors are enabled. No or low oil in the reservoir, system leakage, injector O-Rings, or faulty IPR could cause pressure loss.
Note: If no RPM signal is received, IPR duty cycle will default to 14%
5. FUEL PW - Even though a 1 to 6 mS FUEL PW is shown, it’s possible the IDM did not receive the signal due to a CI or FDCS circuit fault or internal IDM failure.
echo=off
If nothing else, it moves you to the top again so someone with more familiarity with this may see it and comment.
https://www.ford-trucks.com/forums/1...hen-romps.html
https://www.ford-trucks.com/forums/1...-on-start.html
https://www.ford-trucks.com/forums/6...-romp-fix.html
I've used Rotella 15w40 in it. I have no idea what was put in it before I bought it. As far as I know, the injectors are all original.
I don't know where I could "abscond" a scan tool from. I'm living in my RV full time now and often don't know anyone at all in whatever city I happen to be in.
Since I posted last, here are some more observations/problems I've run into. Whatever is going on seems to be getting worse.
Yesterday morning, I started it up fine and didn't have any problems. I was getting ready to hook the RV up and hit the road and I was jockeying the truck back and forth trying to get the truck in the right spot. When I hit the brakes to put it in reverse, it stalled on me for the first time since I got it. I started it back up no problem and it ran the rest of the day without stalling.
Then, about 3 hours outside of Las Vegas, the OD light started blinking and blinked until I got where I was going for the day, about 2 more hours.
This morning, I started it up as normal and it surged just like it did in the video above, but this time with the ICP plugged in. I shut it off and tried starting it in neutral and it didn't surge at all. But I don't know if it was because it was the second time I started it, or because it was in neutral.
Today while making my way to Wendover, NV I noticed that the OD light isn't blinking, but the "Service engine soon" light came on.
Obviously I need to pull codes. The transmission shifts fine and the truck runs normal but something is broken. How do I pull the codes? Can I just grab any OBD-II scanner and read them? I have an OBD-II scanner but I've never used it on this truck before.
