Wont start when warm
Old Mar 23, 2015 | 03:31 PM
Blark's Avatar
Blark
1999 f-550 will not start when the motor gets warm. Starts cold but not as good as it used to
New injector control moduel
Injectors are just over a year old
new low pressure oil pump
new high pressure oil pump with new hoses
glow plugs are just over a year old as well.
320,000 miles with about 3,000 idle hours
Started up great a week ago, drove it and ran fine all day. Meet some friends at a restaurant and when I went back out to fire it up all it did is crank. If you give it a small shot of starting fluid (it was that or pay for a tow bill) it starts up right now and runs.
The only other thing that it has been doing odd before the no start is the RPM would go up and down by a few hundred at an idle.
I am out of ideas and it's getting expensive as you can tell. lol
Old Mar 23, 2015 | 04:02 PM
whitetmw's Avatar
whitetmw
Originally Posted by Blark
1999 f-550 will not start when the motor gets warm. Starts cold but not as good as it used to New injector control moduel Injectors are just over a year old new low pressure oil pump
new high pressure oil pump with new hoses glow plugs are just over a year old as well. 320,000 miles with about 3,000 idle hours
Started up great a week ago, drove it and ran fine all day. Meet some friends at a restaurant and when I went back out to fire it up all it did is crank. If you give it a small shot of starting fluid (it was that or pay for a tow bill) it starts up right now and runs. The only other thing that it has been doing odd before the no start is the RPM would go up and down by a few hundred at an idle. I am out of ideas and it's getting expensive as you can tell. lol
Sounds as though you may have an IPR or Injector Seal Leaking. Next time its hot, try monitoring the below PID's.
echo=on
No Start / Hard Start / Cold / Warm
Tools: OBD-II On-Board Diagnostics, Phase 2 Vehicle Media Communications Unit (Scanner)
1. Select the parameters indicated from the Scan Tool parameter list and monitor while cranking engine.
Data List Monitoring Parameter:
V-PWR 10.5 VDC Minimum.
RPM 100 RPM Minimum (0 - CMP Suspect)
ICP 500 PSI or 3.4 MPAM Minimum
ICPv (KOEO) Spec 0.20v - 0.30v
FUEL PW: 1 MS - 6 MS ( <1 / >6 IDM Suspect)
V-PWR - If indicating a low voltage condition, check battery voltage, charging system or power and ground circuits to the PCM.
DC% - Cranking NTE 20% / 65% is Closed. (IPR Suspect)
2. RPM - Low RPM could be an indication of starting/ charging system problems
3. No RPM indicated with the engine cranking - could be CMP circuit fault, check for DTC’s.
4. ICP - A minimum of 500 PSI (3.4 mPa) is required before the injectors are enabled. No or low oil in the reservoir, system leakage, injector O-Rings, or faulty IPR could cause pressure loss.
Note: If no RPM signal is received, IPR duty cycle will default to 14%
5. FUEL PW - Even though a 1 to 6 mS FUEL PW is shown, it’s possible the IDM did not receive the signal due to a CI or FDCS circuit fault or internal IDM failure.
echo=off
FWIW: If you think that Tow bill would have set you back, That starting fluid will set you back up to $5,000 if it combusts on its exhaust stroke and breaks a Rod. Disconnect the Glow Plugs when using Starter Fluid!
Old Mar 23, 2015 | 04:35 PM
Blark's Avatar
Blark
My oil pressure is 500 and seems to hold. Also had a compression test done and it passed as well.
I understand about the starting fluid. Guess you can call it frustration and aggravation.
Old Mar 23, 2015 | 05:41 PM
whitetmw's Avatar
whitetmw
500 psig is just enough to get it running. You can see upwards of 3,000 lbs. when under load with a DC% as high as 65%.
Almost always, a "Hot No Start" is Oil Related delivery to the HEUI System.
Old Mar 23, 2015 | 06:49 PM
jhl3's Avatar
jhl3
Is it an early 99 or late 99 by build date?
Where did the IDM come from.
Old Mar 23, 2015 | 07:13 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If you can monitor the ICP and IPR duty cycle that would help a lot. Also check the tin nut on the back of the IPR make sure it's snug. And the ICP sensor harness for oil in the connection. If the IPR is holding pressure when cold but failing when hot, the Redneck Rescue is a Big Gulp of ice poured on it, allow to cool for 5 - 10 minutes, see if she starts.
Old Mar 25, 2015 | 04:57 AM
Blark's Avatar
Blark
As of right now I haven't had time to fool with it.
It's starting to get a little rough to start in the mornings. It's only been 40 degrees, it had been starting great.
As soon as I get time I'll work on it and update what I find.
Thanks for all the ideas and input.
spongecop
15
Sep 9, 2016 12:33 PM
tomdavis
Jul 10, 2015 12:29 PM
andym
Apr 19, 2015 09:47 PM
Fordx4jake
18
Apr 14, 2015 09:27 PM
Gregad
Mar 24, 2015 10:12 AM
