OK, first step on my Romp Romp fix
Here's a quick recap of my situation:
1. Romps when it is cold and even when it was not so cold as I would have liked.
2. Checked the GPs and they are all well within limits.
3. Checked the GPR and it was passing at least 12 volts each time.
Now that was in the past in the spring and then this summer it was not an issue. As it got cooler, romp came back. I saw the IPR rebuild post and considered that. I also thought about the synthetic oil fix but did not think that was the problem.
So the other morning when it was about 30* outside, I jumped the GPR posts with a large screwdriver for 60 seconds. Jumped down and went and turned the key. Cranked up like new. Today I measured the GPR and it was only showing 11.2 volts in the WTS mode. No good.
So now I am awaiting this GPR from evilbay. After I get it I will post results. Before anyone posts about the Stancor guzzle unit, I have my reasons for not going that route. I will post the observations. I think my romp was a weak GPR. <table cellpadding="0" cellspacing="0" width="100%"><tbody><tr bgcolor="#ccccff"><td align="right" nowrap="nowrap">
</td><td align="right" valign="top">
</td></tr></tbody></table>
I'm interested in hearing the results of this GPR replacement. I haven't checked my output from the GPR but maybe i should. Question; When your truck romps, does it just romp romp romp kinda romp then run smoothly after that? This is what mine does since it was about 2 years old. You can listen to others start there trucks when it's cold out and theirs romp also, I thought this was just 7.3L diesel. Humm maybe not.
We replaced the GPR in my sons '91 IDI last night, but something I found strange, we put new Batts in at about this time last year, when he turns the ign on, it drops to 10volts, when he hits the starter, it drops to just around 9v or less, 8.5. Seems his new batts are junk already. Am I correct?
Luckily they are 3 year free replacement.
I noticed the new GPR stays on longer then the old one did.
It probably won't do much.
I can start my truck without hitting the glow plug button (converted to manual control) and it will cough once then run, no romps, but with a bunch of white smoke.
I'll be surprised if it fixes your romps, but I really think it's some quirk in the programming that is the root cause. IPR overcompensating for too-high HPOP pressure, vs not enough pulse width or something like that.
Originally Posted by rbaker6336
my last set of wally batteries lasted almost 13 months
Originally Posted by homesteader
What does the Romp Romp sound like ?
Back on topic, Tenn, if it does what he says, and hes not just selling snake oil, that looks like it will be a good find! I would like to see a datasheet on the relay. If it was sold to the military, you know theres got to be a datasheet around. When you receive it, I would ask of you to look for a manufacturer marking, and or p/n if possible.
