Truck ignition stuck on..cylinder lock fine.
Old Apr 14, 2015 | 05:42 PM
BombThreat's Avatar
BombThreat
Hey guys, I've got a issue with my 1993 F350. The other day I went out to start my truck and when I moved the key back to shut it off it turned but felt too easy. Like something disengaged within the mechanism. Now the truck is stuck "on" where ever the ignition key is located. I pulled the cylinder out and it's fine, actually I just replaced it a few months ago anyhow.
Is there a rod or something within the column that I can check to see if it came loose?
Old Apr 14, 2015 | 06:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like the actuator between the key cylinder and ignition switch broke.
Old Apr 14, 2015 | 09:04 PM
Phy's Avatar
Phy
Yup, that's a broken actuator.
Old Apr 14, 2015 | 09:53 PM
BombThreat's Avatar
BombThreat
okay, how bad is that job to fix?
Old Apr 15, 2015 | 05:25 PM
tjc transport
i ain't rite
not that bad. you have to remove the steering wheel and some other things. i have never done a 92 and newer truck, but the 91 and older trucks took about 1 hour for a competent wrench turner.
i know there is a writeup here on how to do it on the 92 and newer trucks, but i just spent 1/2 hour searching for it and can't find it.
SPCRacer51
1997 - 2003 F150
Jul 26, 2018 07:01 PM
Kenton Leong
Jun 4, 2017 07:41 PM
Clockwerk_rat
23
Apr 21, 2017 01:08 PM
SLARGE
Electrical Systems/Wiring
Dec 14, 2005 01:48 PM
Jenners
Apr 26, 2005 01:28 PM
