Sputters immediately after cold start
Old Apr 22, 2015 | 10:33 AM
  #31
ExPACamper's Avatar
ExPACamper
Originally Posted by Glowplugger
The way I understood it any ELM-327 OBD II would work with the 7.3. Is that right?
OBDII is the interface, but the protocol isn't OBDII compliant, just OBD-I
I do use ELM327 Bluetooth to pull codes and run TorquePro, no problem. But you have to set whatever software to ODB-I or FORD protocol.
Apparently "Auto Detect" feature is part of ODBII (so I gather, can't say for certain).
There are those here who know this much better if you want more than just the basics
Draining a little fuel from the bowl removes water, some crud, small contaminants, etc. Just be sure it seals back up. Some have had trouble with those drains leaking.
Mine doesn't leak, but I'm rebuilding the whole bowl with orings and seals over the next few days (started SNOWING here today , so pausing a bit).
Hope this helps.
Old Apr 22, 2015 | 07:18 PM
  #32
white Buffalo's Avatar
white Buffalo
Originally Posted by ExPACamper
.......................Check engine light? Mine is on and I'm driving and ignoring it at the moment. Why? I checked and it is the #3 glowplug. Intermittently I've had cylinder #3 go low. I ordered the UVCH for each side and will replace it.
When you go to replace the UVC harness on that side. Swap the glow plug with another one and see if you can get the code to move to another hole. That way you can see if the cause is the harness or the glow plug. either way - new UVC harnesses after 13 years is a good thing.......
Walleye Hunter
50
Dec 15, 2017 08:43 AM
Frank250Tank
Jan 10, 2017 10:00 AM
ALL BOY
19
Dec 27, 2010 06:49 AM
Jager
17
Nov 29, 2010 08:31 PM
ramblemutt
Aug 18, 2008 10:05 AM
