Sponsored by: Auxito
2003 4.6 rough idle
Old Apr 13, 2015 | 05:41 PM
mainefordman's Avatar
mainefordman
Trailering
Question 2003 4.6 rough idle
I have a 2003 f150 4.6 with a rough idle. I've changed mass air sensor and idle air sensor. Any ideas?
Old Apr 13, 2015 | 10:24 PM
Bluegrass 7's Avatar
Bluegrass 7
Is the check engine light on?
What codes are set?
Your changing part without any proof you need them.
Good luck.
Old Apr 13, 2015 | 10:36 PM
mainefordman
Trailering
I did get codes for mass air and idle air sensors. No CEL
Old Apr 13, 2015 | 11:04 PM
mainefordman
Trailering
Whoops meant idle air control valve not sensor. To much on my mind.
Old Apr 13, 2015 | 11:23 PM
Bluegrass 7
Clear the codes, drive it and and see what comes back so you start over.
Codes for those parts should have lighted a CEL.
At the moment you don't know what the situation is.
Good luck.
Old Apr 13, 2015 | 11:29 PM
sabir's Avatar
sabir
FORD EXCURSION 6.0 roughs with a lot of black smoke, have these codes
Can you help me to figure out these Diagnostic Trouble Codes, please?
Code-1
P0113: Intake air temperature sensor 1 circuit high input
Code-2
P0275: Cylinder 5 contribution balance
Code-3
P0404: Exhaust gas recirculation control circuit range performance
Code-4
P0603: Power train control module keep alive memory (KAM) error
Code-5
P0672: Cylinder 2 glow plug circuit
Code-6
P1102: Mass air flow sensor in range but lower than expected
Code-7
P1335: EGR position sensor Minimum/Maximum stop performance
Old Apr 14, 2015 | 12:41 AM
Bluegrass 7
You need to go to the Diesel forum.
This is the gas motor forum for 97 to 03 years.
From the looks of the codes you have a harness issue of some sort for so many codes.
Good luck..
Old Apr 16, 2015 | 07:06 PM
mainefordman
Trailering
Could a bad fuel filter cause the rough idle
Old Apr 19, 2015 | 02:05 PM
brokenleg's Avatar
brokenleg
Good luck.
Yep.
Old Apr 19, 2015 | 02:24 PM
Bluegrass 7
I got a reply but it does not show up in the thread.
x06, x06, x06.
Is that for this thread?
If yes are you saying 306?
It's misfire cylinder 6.
That sure will cause rough idle.
It pays not to run with to much old history after confusions sets in.
If not disregard the above.
Good luck.
Old Jul 11, 2015 | 08:39 AM
ralph88's Avatar
ralph88
F150 rough idle
I found the 90 deg boot to the pvc valve broken, replaced and cured.
Rotorpilot
Mar 24, 2019 11:39 AM
TracyN
Jan 18, 2016 01:43 PM
stephen410
1997 - 2003 F150
Sep 20, 2006 11:09 PM
ChiliPalmer
Aug 24, 2004 09:02 PM
methos5044
1997 - 2003 F150
Aug 22, 2003 09:45 AM
