Engine Test Run Video
Old Apr 13, 2015 | 02:47 PM
Mtphammer's Avatar
Mtphammer
Got the engine in my 53 F250 running over the weekend.
http://s1288.photobucket.com/user/Mi...xgtmb.mp4.html
Old Apr 13, 2015 | 02:54 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
That sounds great!
Nice job.
Old Apr 13, 2015 | 03:01 PM
Mtphammer's Avatar
Mtphammer
Originally Posted by Jolly Roger Joe
That sounds great! Nice job.
Thank you very much
Old Apr 13, 2015 | 03:06 PM
Schuyles's Avatar
Schuyles
Cool, sounds good! I have a 240 in my '65 F100 and I love it...just starts up and runs and runs....
I bought a Clifford 4v Intake with plans to do a few upgrades...but never went through with it.
Old Apr 13, 2015 | 04:14 PM
Jolly Roger Joe
Originally Posted by Mtphammer
Thank you very much
I'm not familiar with the 300. Did you have to do anything special to mount that carb on the intake?
Old Apr 13, 2015 | 04:23 PM
fordman75's Avatar
fordman75
The 300 sounds great!! I love the sound of a 300 with no exhaust.
That's an aftermarket 4V intake manifold. The hardest part with the 4V carb is usually just the throttle linkage or cable set up.
Old Apr 13, 2015 | 05:10 PM
Mtphammer's Avatar
Mtphammer
Originally Posted by fordman75
The 300 sounds great!! I love the sound of a 300 with no exhaust. That's an aftermarket 4V intake manifold. The hardest part with the 4V carb is usually just the throttle linkage or cable set up.
Exactly as fordman75 said it.
Btw fordman75, wat cable setup do u suggest I use if I want to keep my original accelerator pedal?
Old Apr 13, 2015 | 06:26 PM
toby tough's Avatar
toby tough
VROOOM VROOOM!
Old Apr 13, 2015 | 06:35 PM
fordman75's Avatar
fordman75
You've got a few choices. But here's a couple.
If you want a stock type cable( I mean a factory part not stock 53 part ) then the Ford trucks, vans or Full size Bronco's 80 or newer are a good source. I like to take a piece of wire and kind of lay it out to see how long of a cable you are going to need. Then hit the junk yards with a tape measure or that piece of wire you used and find one that is close enough to work. Ford offered a lot of different engines and carbed or EFI and each one has it's own cable length.
Doing it that way may require some modifications to the cable ends or the carb and pedal.
What I prefer is the universal throttle cable made by Lokar. They offer them in the standard black cable covering and the Braided ss covering. I get mine From Summit racing.
Old Apr 13, 2015 | 09:15 PM
Mtphammer's Avatar
Mtphammer
You've got a few choices. But here's a couple. If you want a stock type cable( I mean a factory part not stock 53 part ) then the Ford trucks, vans or Full size Bronco's 80 or newer are a good source. I like to take a piece of wire and kind of lay it out to see how long of a cable you are going to need. Then hit the junk yards with a tape measure or that piece of wire you used and find one that is close enough to work. Ford offered a lot of different engines and carbed or EFI and each one has it's own cable length. Doing it that way may require some modifications to the cable ends or the carb and pedal. What I prefer is the universal throttle cable made by Lokar. They offer them in the standard black cable covering and the Braided ss covering. I get mine From Summit racing.
Ok I think I'm going to go with the Lokar cable route but I'm still a little wary as to how I'm gonna hook it all up to my original pedal. Maybe I'll just pick up and aftermarket pedal.
Old Apr 13, 2015 | 10:06 PM
fordman75's Avatar
fordman75
I don't even remember how the stock linkage hooks up.
But if you can handle the truck build I see you doing so far you should have no problem adapting the Lokar cable to hook up to your stock pedal. The Lokar cable is a universal cable so it's adaptable.
Old Apr 13, 2015 | 10:43 PM
91Fbody's Avatar
91Fbody
Sounds good!
300 cubes from an I6.
Old Apr 13, 2015 | 11:53 PM
Mtphammer's Avatar
Mtphammer
I don't even remember how the stock linkage hooks up. But if you can handle the truck build I see you doing so far you should have no problem adapting the Lokar cable to hook up to your stock pedal. The Lokar cable is a universal cable so it's adaptable.
Thanks for the confidence booster. I'll go ahead and pull the trigger on that setup. 😎
Old Apr 14, 2015 | 02:52 AM
Mixer man's Avatar
Mixer man
That's awesome!
pikapp
Mar 21, 2017 02:22 PM
Kmatthews
Mar 5, 2017 07:34 PM
mech2161
17
May 16, 2008 08:24 AM
indebt
Aug 31, 2007 02:56 PM
funzjb1
Jul 5, 2007 09:28 AM
