ZF5 problems
Old Apr 12, 2015 | 11:04 PM
sternerboy's Avatar
sternerboy
ZF5 problems
my pick up seems to have really bad transmission problem I just put a new clutch Presser plate and fly wheel and the trans is only about one year old and it is still having problems going into 3rd gear I am out of ideas on how to fix it. It normally does OK when the trans is not worm. Can anyone help with this problem?
Old Apr 12, 2015 | 11:14 PM
guthrie&co's Avatar
guthrie&co
Do you mean pressure plate?
Old Apr 12, 2015 | 11:15 PM
sternerboy's Avatar
sternerboy
Yea sorry not all that great at this typing stuff
Old Apr 12, 2015 | 11:17 PM
guthrie&co's Avatar
guthrie&co
Mine does the same thing. It kind of feels like I can feel the gears aligning for it to go into gear. Mine just isn't bad enough for me to do anything about it yet.
Old Apr 12, 2015 | 11:20 PM
sternerboy's Avatar
sternerboy
This is the third trans I have put in it. I have just installed the Ts 6 position chip and it kinda helped but it still really bad. Do they make a trans cooler for the zf5?
Old Apr 12, 2015 | 11:25 PM
fordpride's Avatar
fordpride
Check the pedal box bushings
Old Apr 13, 2015 | 09:43 AM
fnfast88's Avatar
fnfast88
Clutch/brake pedal assembly bushing. To test this push clutch pedal to the floor and now push the brake pedal hard if you feel you left foot move you need to pull the steering column lower shafts brake booster. Drop the pedal assembly out and rebus it. Don't wait too long like I did and have to replace the whole thing from metal on metal wear. Also the little white bushing on the clutch lever could be worn out. Clutch master cylinder. The function of the master cylinder will be fine but the eyelet that the bushing and lever go in could be elongated making slop in the pedal.
I hope these trouble areas help.
Old Apr 13, 2015 | 02:21 PM
golfer.61's Avatar
golfer.61
throw 4 quarts of Redline MTL in there and ditch the atf stuff. That will help with better shifting...
Old Apr 13, 2015 | 06:55 PM
sternerboy's Avatar
sternerboy
the pedal Bushings are bad for sure... where would I get those? And I will have to try that new fluid. It does seem like the atf is not all that great. Thank you for all the help. I am a new member and this is a great site
Old Apr 13, 2015 | 07:30 PM
fordpride's Avatar
fordpride
Read this
https://www.ford-trucks.com/forums/9...pic-heavy.html
Old Apr 13, 2015 | 07:34 PM
sternerboy's Avatar
sternerboy
That is amazing thank you very much should be getting it done this weekend
sternerboy
20
Apr 15, 2015 09:33 PM
kbddbd
Jun 5, 2005 06:20 PM
Cobrajet25
1983 - 2012 Ranger & B-Series
Jun 15, 2004 12:24 AM
Josh79
Mar 4, 2004 07:34 PM
Josh79
Jan 21, 2004 09:33 PM
