Sponsored by: Kumho
aluminum wheels
Old Apr 12, 2015 | 04:06 PM
Hyperactive460's Avatar
Hyperactive460
aluminum wheels
Any ideas on how to clean aluminum turbine wheels ? I already tried aluminum wheel cleaner and it worked to some degree but Istil ddidn't get all of it off.
Old Apr 14, 2015 | 05:52 PM
pbsdaddy's Avatar
pbsdaddy
The only real way to clean raw aluminum wheels is to polish them. You can buy good polishing pads and cones at any NAPA store or on line. Some of the smaller foam polishing wheels will work for the lighter stuff.
Start with a decent compound. I use tried and true Dupont polishing compound. It will take time and effort. There are no short cuts. If the crud, on the wheel, is especially tough, you could try Dupont rubbing compound. It is a larger grit. Just be careful with it as it can scratch aluminum and then you'll have to polish out the scratches.
After it is clean, use a good automotive polish then wax. They should look great for quite a while.
Old Apr 20, 2015 | 10:40 PM
7DF250's Avatar
7DF250
steam clean or parts dip? Media blast with baking soda or walnut shells
Old May 1, 2015 | 12:18 AM
Econo4spd's Avatar
Econo4spd
oven cleaner.
Don't let it sit too long and will probably have to polish some afterwards.
Old May 5, 2015 | 12:00 AM
Tundra Pony's Avatar
Tundra Pony
Maybe get them acid washed?
jonmammenga
Jan 10, 2016 09:42 AM
kyflaresideon20s
Appearance & Dress-Up
Jun 12, 2011 10:19 PM
Pocket
Mar 21, 2007 11:58 AM
Monty06
Mar 28, 2006 04:38 PM
black wolf
1983 - 2012 Ranger & B-Series
Feb 8, 2004 06:51 PM
