Wiper Motor Question
Old Apr 12, 2015 | 06:43 AM
hickory1991's Avatar
hickory1991
Originally Posted by Torquin
Shucks, that price is the same as new for just the switch. Thanks a bunch. I'm gonna order that.
Does the box just hang under the dash, or is there a particular way it is supposed to be mounted?
Thanks,
Chris
Mounts on the bottom lip of the dash below switch. Behind the dash where you can't see it. One screw.
Old Apr 12, 2015 | 06:44 AM
bkaul's Avatar
bkaul
Thanks,
Chris
Not sure - my truck doesn't have intermittent wipers; I've got that post tagged in my "watched items" on ebay but haven't done the conversion yet myself. Maybe Bill's got a diagram?
Old Apr 12, 2015 | 12:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No parts catalog pic of intermittent wiper parts.
Old Apr 12, 2015 | 12:18 PM
NumberDummy
Originally Posted by bkaul
There is a module besides the switch. These are the parts you would need, though you can probably find them cheaper at a junkyard:
Wiper Delay Switch Ford Pickup Truck 1973 1974 1975 1976 1977 1978 1979 | eBay
Look at the pic of the governor, its prefix is marked E7TF .. its basic part number and suffix have been scratched off.
This set up is from a 1987/91, not 1973/79! Seller probably assumes that potential buyers will think E7TZ refers to 1977. It does not!
1987/91 F150/350 & Bronco intermittent wiper governor ID engineering number: E7TF-17C476-AB or CA
This ID number cross referenced to part number E7TZ-17C476-A which was replaced in 1989 with E9TZ-17C476-A
Old Apr 12, 2015 | 07:03 PM
Torquin's Avatar
Torquin
Bill,
So does that mean it won't work?
Thanks,
Chris
Old Apr 12, 2015 | 09:20 PM
bkaul's Avatar
bkaul
I noticed that, but pretty sure I've seen threads with people here using modules from that era to retrofit intermittent wipers into '73-79s too. He's not selling as factory original number-matched parts, but as a conversion "kit" to upgrade. I don't know of any reason it wouldn't work in that regards ... ?
Old Apr 29, 2015 | 09:06 AM
bkaul's Avatar
bkaul
From reading other threads, the later-model switch/governor will work as an upgrade, just may need to swap a wire on the two-wire connector to get the washers working:
https://www.ford-trucks.com/forums/1...-question.html
I think I'm gonna do this myself while I've got my truck's instrument cluster out to get to the wiring anyway.
heyitsjustus
May 28, 2019 09:47 PM
fmackey
Feb 19, 2015 01:57 AM
Pastortom1
Aug 23, 2011 10:55 PM
crescentwrencher
Apr 4, 2008 09:58 PM
Daves94vert
Jun 17, 2005 04:06 PM
