GAS ISSUE
Old Apr 10, 2015 | 12:20 PM
Renee Finn's Avatar
Renee Finn
GAS ISSUE
I recently inherited my uncles 1973 f250 it has been sitting for 10yrs, it actually started (after normal maintance of course) have some issues, major one is to much gas.. we dropped the tanks cleaned them , replaced all filters, re-built the carb but now gas is overflowing in engine if it back fires it catchs on fire , im at a lose
Old Apr 10, 2015 | 12:41 PM
gatorfor88's Avatar
gatorfor88
Sounds like float is stuck open. That is if gas is actually coming from carb.
Old Apr 10, 2015 | 06:32 PM
Blue and White's Avatar
Blue and White
Again, assuming its the carb, a gentle tap on the float bowl with a hammer may free up the float... but probably time to rebuild the carb or swap a reman carb.
Old Apr 10, 2015 | 08:42 PM
Jdeshler's Avatar
Jdeshler
I agree with the guys, the float is likely wide open.. If a sharp tap doesn't fix it, open it back up and make sure you put the o-ring under the needle seat
Old Apr 10, 2015 | 08:49 PM
Jdeshler's Avatar
Jdeshler
You can also bend the float downwards(holding the metal part that hinges with needle nose pliers) to lower the gas level, thus pushing harder on the needle valve
Old Apr 12, 2015 | 03:39 AM
Renee Finn's Avatar
Renee Finn
thank you I will try it
Old Apr 13, 2015 | 12:20 AM
wdfp's Avatar
wdfp
Which carb is it? Except for the common piece of something stuck on the needle valve, different carbs have different ways of doing that..
Old Apr 13, 2015 | 12:50 AM
racejeep1998's Avatar
racejeep1998
My .02 get a nice 600cfm carb and tune that puppy with a wideband o2. The truck cost you nothing, might as well make doimg this easy on yourself. You dont need the extra setup they run. In this link that logs everything. Just a plain lm2or autometer 3041 wideband will be good. Like this http://www.superchevy.com/how-to/engines-drivetrain/0510ch-carburetor-tuning-gas-mileage/
Old Apr 13, 2015 | 12:57 AM
dustyroad's Avatar
dustyroad
Originally Posted by racejeep1998
My .02 get a nice 600cfm carb and tune that puppy with a wideband o2. The truck cost you nothing, might as well make doimg this easy on yourself. You dont need the extra setup they run. In this link that logs everything. Just a plain lm2or autometer 3041 wideband will be good. Like this Gas Mileage - Carburetor Tuning Techniques - Chevy High Performance
how can you make that CFM recommendation when you don't even know what kind of engine is in their truck. Maybe their carb builder did something wrong and just needs tweaked up a bit and not replaced. Hell it could have been a faulty float.
Another case of spending someone elses money.
Old Apr 13, 2015 | 12:12 PM
racejeep1998
I suppose. 600cfm works pretty good for most of these 360 and 390's which I figured his truck has.
JRB65
Dec 22, 2012 05:31 PM
nzabka
Sep 15, 2005 07:40 AM
drive_old_ride_new
May 30, 2004 07:08 PM
78fordman
Oct 30, 2003 01:23 AM
madpunker22
Sep 12, 2003 11:08 PM
