Sponsored by: Real Truck
oil pan
Old Apr 9, 2015 | 08:21 PM
Fellenz's Avatar
Fellenz
oil pan
Changing the oil pan this weekend!
2003 F250 6.0 4wd.
I've read I can lift the engine a couple inches, and slide her out; anyone have any tips before I get my hands dirty?
Old Apr 14, 2015 | 07:34 AM
brobrad's Avatar
brobrad
2003 F250 6.0 4wd.
Read on another forum just a few minutes ago that it was not necessary for the 6.0. They said it could be done with engine in place. I can't confirm or deny.
Old Apr 14, 2015 | 09:15 PM
Fellenz's Avatar
Fellenz
Project done!
I ended up lifting the engine right until the turbo touched the firewall, and almost had to remove the turbo, but a rubber mallet, patience and careful fingers got the old one of, and new one on.
It took me a couple hours, but anyone doing it them selves in the way that I did should plan on at least a day for the oh ***** moments.... Because your gonna have them.
Upper radiator and shroud bolts off (6)
Engine mount bolts off, 21mm (4)
Lift engine, I jacked it from the crank pulley using a 2x4.
All the pan bolts, 8mm....have extensions and an imagination and patience with them!
Drop oil pickup tube in pan, 8mm (2)
Remove pan
New Pan with oil pickup inside.
Bolt up oil pickup, small hands and patience here!
All bolts on, slowly jack down, engine and radiator bolts.
Fill oil and service since your already feeling greasy.
Say a prayer.
Test drive.
Or at least that was my checklist.
Old Apr 15, 2015 | 01:37 AM
clem1226's Avatar
clem1226
Does the 6.0 use a pan gasket?
Just curious.
Old Apr 15, 2015 | 06:36 AM
Fellenz's Avatar
Fellenz
It has an o-ring seal.
I didn't replace mine because it looked fine and no leaks. I
makenagillies
1978 - 1996 Big Bronco
Jul 13, 2016 09:42 AM
bbender85
Jun 15, 2012 11:10 AM
Z-MAN
Mar 6, 2012 10:50 AM
drew1701
Nov 5, 2006 08:50 AM
broncofrk
Bronco II
Dec 24, 2004 04:46 PM
