ideas to remove this bolt
Old Apr 14, 2015 | 01:16 PM
emeraldcoupe's Avatar
emeraldcoupe
thanks for the ideas guys
Originally Posted by Canus
Try MIG welding a nut onto it. The heat should loosen the threads and the nut will allow you to use a socket to remove.
this worked perfect. it was out in about a minute
Old Apr 14, 2015 | 01:44 PM
vettman's Avatar
vettman
On my 76 F350 the seatbelt bolts were T50. Try hammering on a T55 impact socket. The ridges on the T55 may be able to get enough purchase to break it loose. It worked for me.
Old Apr 14, 2015 | 01:46 PM
emeraldcoupe
thanks but I already got it out, see my post above yours.
Old Apr 14, 2015 | 01:49 PM
vettman's Avatar
vettman
Oops--I completely overlooked your success. Congrats on getting it out.
Old Apr 14, 2015 | 02:03 PM
HoustonDave's Avatar
HoustonDave
That is a round Tox head bolt, probably T50. Soak it in Kroil or other penetrant while you use a Dremel and cut-off wheel to carefully cut off opposing sides on the bolt head so you have flats to crank on with an appropriate sized wrench - (_) shaped. Lot more certain than drilling it out or trying to EZOut it.
Old Apr 14, 2015 | 02:04 PM
HoustonDave
as did I... was on the second page and I commented at the end of the first. Ah well...
oldracerjones
16
Apr 2, 2019 08:39 PM
FordBoy2012
1997 - 2003 F150
Apr 14, 2013 07:07 PM
F150NVa
2004 - 2008 F150
Feb 15, 2008 06:42 PM
1stoldtruck
Garage & Workshop
Aug 30, 2003 02:57 PM
MRB068
Nov 30, 2002 12:07 PM
