Wheel Stud Removal
Old Nov 25, 2002 | 12:40 PM
MRB068's Avatar
MRB068
Wheel Stud Removal
I have a 98 Explorer v6 2wheel drive. One of the studs is striped I have a powerbuilt stud remover but I have no Idea how to use it an someone help me?
Thanks
Michael
Old Nov 26, 2002 | 10:47 AM
Dough01's Avatar
Dough01
Wheel Stud Removal
i would say use a block of wood and hit it like that .... its kinda ghetto .... but working with tractor trailers we do things like that haha
Old Nov 30, 2002 | 11:11 AM
burk97's Avatar
burk97
Wheel Stud Removal
use a punch and a big hammer and drive it out
Old Nov 30, 2002 | 11:52 AM
Dialtone's Avatar
Dialtone
Wheel Stud Removal
To pull the new stud back in, get a new nut or 2 and several flat washers. Start the bolt thru the hole, pile on the washers, and put one nut on the stud with the flat side against the washers then screw it down. This will pull the stud into the hole like a reverse press.
May want to lubricate everything well before starting, and throw away the pulling nut when finished. Be careful not to strip the replacement stud.
Dialtone
Old Nov 30, 2002 | 12:04 PM
Dough01's Avatar
Dough01
Wheel Stud Removal
what about lock tight ? and useing anti seize on the stud threads before putting the tire back on .... that is some good stuff
Old Nov 30, 2002 | 12:07 PM
Dough01's Avatar
Dough01
Wheel Stud Removal
