3 Speed replacement - whats compatible?
Old Apr 9, 2015 | 01:22 PM
gravydude's Avatar
gravydude
I have a 1978 F150 with the bigger three speed trans. (Three on the tree)
I believe the trans housing is 9.25? Anyway, it's the larger one of the three speeds.
What year or model of transmissions are compatible for a replacement?
I have a lead on a 68 F100 three speed, but uncertain if it'll work?
1978 F-150 300ci
4x2 three on the tree
Single piece drive shaft
Old Apr 9, 2015 | 01:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford type 3.03 3 speed (on the tree) manual all syncromesh transmission:
1963/83 F100 / 1963/86 F250 / 1966/77 Bronco / 1975/86 F150 // 1965/87 Econoline // Misc 1963/80 Ford/Merc Passenger Cars.
1968 same trans as 1978, but there may be differences in the length of the output shaft and extension housing.
Why not rebuild what you have as NAPA has all the parts.
Old Apr 9, 2015 | 02:14 PM
gravydude's Avatar
gravydude
Found one for $50 (if it's the right size?)
Also, I've never rebuilt one before.
Are they a piece of cake to rebuild?
Old Apr 9, 2015 | 02:18 PM
85e150's Avatar
85e150
They are supposed to be fairly easy to rebuild, but ymmv:
https://www.ford-trucks.com/forums/1...on-issues.html
If you have someone do it, make sure they are familiar with them or at least older manual transmissions in general. "I've never done one but how hard could it be..." is not a good response to the question.
Old Apr 9, 2015 | 07:55 PM
NumberDummy
Old Apr 10, 2015 | 07:09 AM
gravydude's Avatar
gravydude
Thanks a bunch folks !!
Old Apr 10, 2015 | 07:43 AM
76F15OSuper's Avatar
76F15OSuper
I had a Three on a tree - Inline 6, years ago. The Trany went bad and I ended up getting a 4 speed (w/od) out of a mid 80's pickup. Cutting a hole in the floor for the shiftier, Mounting the "hump cover" and moving the lower trany mount off the 3 speed to the 4 speed is the only thing extra I had to do.
hillcountryflt
Aug 21, 2014 11:51 AM
cadstar13
Oct 23, 2013 11:27 PM
limptera13
Apr 19, 2010 10:06 AM
anthony605
Dec 28, 2005 02:54 PM
