Mazda 5 Speed Compatability Question
Old Dec 26, 2005 | 10:04 PM
anthony605's Avatar
anthony605
I have a 1995 F-150 4x4 with the I6 Engine and 5 Speed Mazda Trans. What years are the 5 speed Mazda Trans the same? My trans is starting to grind and I have the oppurtunity to buy one from a 1989 for cheap. Do you know if the one from the 1989 will fit my 1995?
Old Dec 28, 2005 | 02:32 AM
phoneman91's Avatar
phoneman91
I would think that the two different year transmissions would interchange. One way to check this would be to check on one of the internet sites that rebuild manual transmissions and see if there is a part number change between the two model years of M5R2 manual transmissions.
Or you could check car-parts.com--an internet site of national wrecking yards and see if there is interchangeability between the two model year transmssions.
Or you could call a local wrecking yard and have them check in the Hollander Interchange Manual(I think that is what it is called) .
Old Dec 28, 2005 | 04:48 AM
anthony605's Avatar
anthony605
Thanks! Ill give it a shot!
Old Dec 28, 2005 | 04:51 AM
ford390gashog's Avatar
ford390gashog
is this the M5OD ?
Old Dec 28, 2005 | 08:05 AM
EPNCSU2006's Avatar
EPNCSU2006
The only difference I can think of is that the 87-91 trucks used a mechanical speedometer driven off the tailshaft of the transmission (or transfercase since it is 4wd).
Old Dec 28, 2005 | 12:29 PM
andym's Avatar
andym
Yeah, they're identical. You'd only have issues with the speedo cable if both trucks were 2wd and you were swapping a newer tranny into an older (pre-92) truck.
Old Dec 28, 2005 | 01:00 PM
lexluthr69's Avatar
lexluthr69
Also be aware that the synchros on 5th/Reverse are different starting about July of '90. "Old style" were 42 tooth synchros, while the "new style" are 33 tooth. Something to keep in mind should you decide to rebuild it.
Old Dec 28, 2005 | 02:46 PM
Zero Obliquity's Avatar
Zero Obliquity
Are they interchangeable, ie 33 tooth syncros in a pre 90 M5OD?
Old Dec 28, 2005 | 02:54 PM
lexluthr69's Avatar
lexluthr69
As far as I know, the synchros are not interchangeable. However, the transmissions as a whole are. The synchros would only pose a problem if you intended to rebuild it, and grabbed the synchros based off the year of your truck, and not the transmission.
I'm about to put a M5R2 from a '93 into my '89, so there is no fitment issue. Only an internal parts difference.
bigbluetruck
27
Mar 12, 2017 10:03 AM
Kapusta
Dec 8, 2016 01:07 PM
408 Torquer
Dec 7, 2016 09:13 AM
thompsj0784
Aug 18, 2015 04:30 PM
tyzsdad
16
Aug 11, 2004 05:05 PM
