after cat mod problems
Old Jul 25, 2003 | 11:18 PM
montster's Avatar
montster
I preformed a high tech catalytic converter mod.(popped off muffler and smashed out all the guts of the cat with a tire iron)
but I find that now often when I shift I will backfire, could it be that I need to advance the spark or something? doesnt do it all the time but it didnt do it before. It dosnt really bug me but it scares the crap out of the girlfriend, and I just got her used to the no doors thing so any help or ideas would be great.
Thanks
Old Jul 26, 2003 | 06:53 PM
DT-466man's Avatar
DT-466man
if its just a poping sound when you let off the throttle no
It sound cool though doesn't it
Old Aug 4, 2003 | 08:35 PM
jj292's Avatar
jj292
I just breformed the same mod on my 89 f150 (only i used a pice of pipe ) an am experiencing the same popping sound when i let off the throttle. What is causing this and how can i fix it? Even if it is not dangererouse for the engine and is was cool for the fisrt day or so but now it is just anoying.
Please help! JJ
Old Aug 4, 2003 | 08:56 PM
montster's Avatar
montster
I put a cherry bomb and 12 inches of pipe with a turn down (Icut the stock exhaust pipe from very end to after the bend so it had a turn).It seems to have really deepened the rumble and it was cheap, cherry bomb cost about $32 . sounds really good. Also have to be a little quicker getting the foot off the gas as I clutch. I was thinking about advancing the timing slightly to see if that would help.If anyone has any thoughts on this please let me know.
Old Aug 4, 2003 | 09:58 PM
Silver Streak's Avatar
Silver Streak
It's caused by the unburned fuel in the exhaust exploding when they get to some oxygen. To fix it you either have to get the extra fuel out of the exhaust, or keep it from finding oxygen until it has cooled to a temp. that won't initiate combustion.
Old Aug 5, 2003 | 11:55 AM
jj292's Avatar
jj292
how do I do those things?
Old Aug 5, 2003 | 08:13 PM
Silver Streak
If there is air in the exhaust it's probably due to an exhaust leak. Excess fuel is probably a carb calibration issue, but some pull too much fuel when the vacuum spikes at throttle closure no matter what. You can try closing the idle mixture screws a little, but that might not be enough.
Old Aug 5, 2003 | 08:40 PM
paulfix's Avatar
paulfix
My guess is that the air is being pumped in from the smog pump.
Try to plug both vac lines to the valves that are controlling the air injection system
Old Aug 5, 2003 | 09:59 PM
montster's Avatar
montster
My truck is over 20yrs old so I am emissions exempt. so what parts of the emissions stuff can I pull off to improve preformance and fuel mileage.
thanks
Old Aug 6, 2003 | 07:02 PM
Bob_Smith's Avatar
Bob_Smith
That popping sound is just your engine racking (why it's called racking, I can't remember right now and it's the hick term for it) and the only way I know to get rid of it is to get a muffler (if you don't have one) or if you have one and it still does it, get another kind of muffler. I think glasspacks, strait pipes, and most race or strait-through flow mufflers let your truck do this. Your engine "racking" won't hurt anything, unless you have your exhaust clamped together and it's not clamped real tight. And you might loose an exhaust tip or two if they aren't on real good either.
Old Aug 6, 2003 | 08:22 PM
1987LTDmasta's Avatar
1987LTDmasta
he's on the ball..
my '86 Thunderbird 3.8V6 experienced the same exact thing, even with a muffler! emissions-wise it ran perfect, passed emissions with flying colors. the car was equipped with the CFI setup so air/fuel was not adjustable.
what you need to do is eighter replace or remove entirely the cat. this will allow all unburned fuel to just exit the pipe or get absorbed by the cat. believe me, i've tried several types of mufflers and none ever even muffled the popping sound.
Old Aug 6, 2003 | 09:48 PM
troposcatter's Avatar
troposcatter
My courier used to do that also after I dumped the pellets out of the cat and put on a straight pipe, I leaned out the carb with smaller jets and made a stainless steel tip and I just clamped it down a little till it popped less. It worked real well and passed emissions it only popped when you decelerated hard and then not badly.
thednthek
Mar 8, 2016 02:36 PM
tw
2009 - 2014 F150
Dec 28, 2015 12:29 PM
86f250hd
Sep 14, 2014 12:47 PM
ACFX4
Exhaust Systems
16
Oct 23, 2013 09:59 PM
ford5.8
Exhaust Systems
Jun 3, 2004 10:15 PM
