Heater blend door missing? need help
Old Apr 8, 2015 | 03:24 PM
85Supclub's Avatar
85Supclub
Hey everyone, so with my new truck, one thing I was noticing was that I only have full bore heat, not temp control.
Got the controls apart and discovered the cables going to the blend door were cut. Ok, so then I removed the glove box and the panel to get to the blend door and I think it is totally AWOL! The push/pull actuator is still on top but I don't see it connected to anything.
Does anyone have a pic of what the door should look like installed? Can I replace the blend door without taking things apart any further?
I will be heading to a junkyard soon and was hoping to find a decent cable, actuator and door.
It is a 1996 F250 with factory A/C. I was thinking there may be other models that use the same setup?
Old Apr 8, 2015 | 05:26 PM
ncranchero's Avatar
ncranchero
92-96 F150/F250 97 F350-up will get you what you want.
Parts diagram
jrh32
Dec 19, 2016 11:14 PM
wikdwest
Dec 24, 2012 03:37 PM
jdev6
Dec 11, 2007 09:34 AM
copyman
Oct 20, 2007 03:55 PM
kinglg
Jun 14, 2003 01:17 PM
