Sponsored by: Real Truck
auto down on pass side window 06 SD?
Old Apr 7, 2015 | 11:51 PM
kengarchow's Avatar
kengarchow
i was wondering if anyone has come up with a way to make both window buttons on the driver side door have auto down feature?
wonder if you could get a second switch and use the driver side auto switch to convert the pass side of the switch with out auto down also
thanks
Old Apr 8, 2015 | 09:11 PM
NorEasterMA's Avatar
NorEasterMA
Subscribing to this. I have had the exact same thought about doing a conversion using a donor switch. If I can find two sets cheap enough I may dive right in...I think it's absolutely possible to do it, I just haven't wanted to spend $150 on two switches to hack up!
Old Apr 9, 2015 | 08:50 AM
kengarchow's Avatar
kengarchow
ill hunt around for a spare switch or two
and see what i can figure out
Old Apr 9, 2015 | 08:57 AM
FX4ALL's Avatar
FX4ALL
Sub'n
I couldn't believe it didn't have auto up & down for both front windows... I can't recall the last vehicle I owned that did not have that.
Old Apr 9, 2015 | 06:46 PM
LindenBruce's Avatar
LindenBruce
The electronics is prolly not in the switch. I know you will need a dual mode switch. But I think the rest would be a timer, a relay and a limit switch? Take a look at the driver's side wiring diagram and I bet you can figure it out easily enough. B.
Old Apr 9, 2015 | 08:19 PM
kengarchow's Avatar
kengarchow
found an extra switch today and took it apart, and the drivers side of it has an extra detent in it and and extra wire that i bet goes to the electronics for the auto down. but was able to take the switch cover of and put it on the pass side of the switch.
now need to install an auto down unit that i think can be purchased aftermarket
Old Apr 9, 2015 | 09:27 PM
robs97z28's Avatar
robs97z28
subscribe! I've been want to do this for years!
tjc transport
Jun 14, 2018 06:31 PM
st.rodder2
Sep 29, 2016 09:20 AM
ChuckHD
Sep 2, 2015 03:13 PM
Emel
6.7L Power Stroke Diesel
32
May 14, 2012 06:48 PM
Munkey
Nov 13, 2004 08:25 PM
