beware the arp set does not have all the correct bolts for an f150. I bought that arp bolt set and i still had to source bolts.
anti seize would be good on all bolts especially the ones that go thru the timing cover to block.
I had to break my cover so I wouldn't have to pull the block out. I guess then money wasn't an issue and just bought a new one. on the bright side bolt came right out.
Good advice on the anti-seize.
Do NOT recommend stainless steel bolts for this. Most people don't realize how weak most SS bolts are compared to regular steel. You can buy high strength SS bolts, but they are much more expensive.
