Does anyone know if the two piece fuel pump eccentrics for the FE motors interchanges with any other ford motors (particularly the 302)? The tab on mine sheared off and I can't find any online . Before you say it, no I'm not about to switch over to electric fuel pump instead of finding a new eccentric. If all else fails I guess I'll be spending a day pulling apart jy motors.
One thing to check before you install the new eccentric, make sure the drive pin for the camshaft doesn't stick out too far. If it does and you install the new eccentric, it will crush the tab and flatten it out.
I had to grind my pin down to keep that from happening, it was a new cam and pin. I didn't catch that the first time so I had to get a second eccentric.
