trans interchange
Old Apr 6, 2015 | 05:49 PM
1988Mudddogg's Avatar
1988Mudddogg
trans interchange
I have a F350 1996 with an Fz trans. Can i put in a S5-42 trans in place of my S5-47? Would it mate up with no issue?
Michael
Old Apr 6, 2015 | 06:00 PM
bigbadwolfe's Avatar
bigbadwolfe
it will fit no problem but the 42 is made for an idi not a powerstroke it is rated for less power and geared a little different i have put the 42 in powerstroke b4 they just dont seem to last they end up cracking the bell housing now mind you these are tow truck that i am doing this with so they see alot of heavy loads constant towing and many different feet on clutch may be under normal use they will hold up fine idk but i do know i have done it 3 times and broke all 3 ssame place
Old Apr 6, 2015 | 07:14 PM
1988Mudddogg
Thanks man. It is just a Dailey driver with a small trailer every now and then. Does it have a taller 5th?
Old Apr 6, 2015 | 08:31 PM
ReBilld's Avatar
ReBilld
The S5-42 is what came in the Powerstrokes in 94.5 and '95. Only the '96 and '97s had the S5-47s. The 42 will bolt right up where the 47 was no problem. The biggest difference in the two are the gear ratios. The 47s have lower first three gears and reverse than the 42s, but it will work.
Mike1
May 28, 2015 08:41 AM
Bentizzy
Jan 17, 2015 09:20 PM
pupsford
Sep 19, 2008 09:21 AM
SPODEBOY
Feb 22, 2006 03:00 PM
lr
Dec 27, 2000 09:36 PM
