Sponsored by: Real Truck
2-speed fuel pump?
Old Apr 6, 2015 | 11:45 AM
pdqford's Avatar
pdqford
2-speed fuel pump?
I'm working on a 1999 F-450 with the V-10.
I'm trying to get my head wrapped around the wiring for the fuel pump (aft tank).
According to the wiring diagram there is a fuel pump relay in the relay block that supplys power to the fuel pump. I'm okay with that.
But there is also a "fuel pump speed relay" on the ground side of the fuel pump circuit. If I'm reading the diagram correctly, when the PCM energizes the "speed relay", the fuel pump ground is sent through a resistor to ground and when the PCM de-energizes the "Speed relay" the fuel pump ground bypasses the resistor and goes straight to ground.
Is this in effect a two speed fuel pump?
And does anyone know what the PCM's logic is?
Like when is the fuel pump put into high speed and when does it go into low speed?
Thanks for any light you can shed on this.......................Jim
Old Apr 7, 2015 | 08:30 AM
MR3C's Avatar
MR3C
I'm guessing its dependent on load/engine speed/calculated fuel flow requirement/pressure
Old Apr 7, 2015 | 08:49 AM
05F250DSL's Avatar
05F250DSL
I'm not sure what problem you are troubleshooting but some of the 450's and up have had the fuel tanks delaminate Cause fuel flow problems.
Old Apr 7, 2015 | 12:30 PM
pdqford's Avatar
pdqford
The fuel pressure fades on long hard pulls. We've cleaned the tank and the filter sock and changed the fuel filter, all of which have helped, but its still not quite right.
Next I wanna dead head the fuel pressure regulator to see if its leaking pressure back to the tank
And would really like to know what conditions cause the PCM to activate/deactivate the speed relay and how much that resistor will lower the fuel pump voltage and when before springing for a new pump.
EconolineFan
General Automotive Discussion
May 10, 2019 10:39 PM
g_k50
1983 - 2012 Ranger & B-Series
15
Sep 1, 2014 02:32 PM
JoePeeper
Oct 23, 2013 04:24 PM
TheWhiteBeast
24
Jul 31, 2011 10:24 AM
gearshift101
Nov 2, 2004 03:49 PM
