Sponsored by: Real Truck
Brake Fluid: Ought It Be Changed?
Old Apr 7, 2015 | 06:20 AM
TomBrooklyn2's Avatar
TomBrooklyn2
Trailering
Question Brake Fluid: Ought It Be Changed?
Should brake fluid be changed periodically?
If so, how often?
Old Apr 7, 2015 | 06:48 AM
MR3C's Avatar
MR3C
Yes, every 18-24 months, better still is to monitor the moisture content in the brake fluid with a meter
Old Apr 7, 2015 | 10:48 AM
droldsmorland's Avatar
droldsmorland
All fluids need to be changed. Axles, transfer case, trans, power steering, coolant, brake fluid.etc...I do my brakes about every 2 years on all of my vehicles. If you are a DIY'er purchase the bug spray style pump bleeders(Summit , Jegs). Make sure you get the right master cylinder adapter and use the correct brake fluid. Fresh brake fluid. Never use fluid that's been sitting longer than 3-6 months. Its very hydrophilic (likes to absorb water). Your brake system will reward you with longevity. I have a 95 GC Jeep that has 226K on original rear calipers. Only reason I changed the fronts is the piston dust seals...well turned to dust.
Old Apr 7, 2015 | 11:07 AM
Tedster9's Avatar
Tedster9
I like the speed bleeders way better than the pumps. Making the process quick and easy goes a long way to getting folks to at least think about it. Brake fluid is hygroscopic for a reason, though - If it weren't, brake lines would freeze solid in cold weather with any moisture present.
Old Apr 7, 2015 | 11:43 AM
hodge5's Avatar
hodge5
I don't have an aversion to replacing brake fluid, but I've put a lot of miles on a lot of vehicles, I have not experienced caliper failure, and I don't change the brake fluid unless I am replacing components. It is a choice, not a necessity unless you drive excessive amounts of mileage.
Old Apr 7, 2015 | 12:52 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I replace every ~2 years. Seems like there are always a lot solids suspended in the brake fluid.
Old Apr 7, 2015 | 08:57 PM
PaxtonShelby's Avatar
PaxtonShelby
Every time I flush the brake system I can feel the difference in the pedal afterwards.
Old Apr 7, 2015 | 09:12 PM
rcbuehler's Avatar
rcbuehler
A few years ago, I would have said "No, it's a closed system."
But then I had my 01 in for a state inspection. Was told that my brakes needed bled. No way. I bought it new. Never opened a line. And this was a shop that I totally trust. I guess over time it was slowly degrading. I didn't realize the pedal was taking longer and longer to build pressure.
Got it back and I could not believe that difference in the feel of the brake pedal.
So Yes, keep an eye on the brake fluid and change it.
onug
2015 - 2020 F150
15
May 6, 2016 10:57 PM
jonmammenga
Nov 17, 2014 09:15 PM
Headviking
Aug 7, 2013 12:25 PM
90XLT_Silver_Bullet
Aerostar
Oct 24, 2003 08:50 AM
