Injectors
Old Apr 6, 2015 | 08:00 AM
ethiele74's Avatar
ethiele74
Injectors
Short and sweet just want to be sure i got the spool valves back in the right way got intrupted last night and dont want to find out after i get her buttoned up...
Old Apr 6, 2015 | 04:08 PM
dannyboy950's Avatar
dannyboy950
No picture??? Good description????
Old Apr 7, 2015 | 12:56 AM
Yahiko's Avatar
Yahiko
They are the invisible type. Got to have these on to see them >>
Oh I am a smart *** tonight.
Sean
Old Apr 7, 2015 | 07:02 AM
ethiele74's Avatar
ethiele74
umm yes you do and the part i was referring to was the large end vs the small end of the spool valve. by the way invisible ones are a booger to clean....lol
Old Apr 7, 2015 | 01:21 PM
Yahiko's Avatar
Yahiko
If you want to check I think someone got then in backwards and got a no start
or a bad running engine . Once they swapped it back the problem was gone. But use the search and you should find that post it about 9 mo old(?) maybe.
Now the funny part. I have a book of invisible checks I use to pay bills with
the problem is once I set then down after filling then out also with invisible
ink they go missing. What's with that?
Sean
P.S. I even tried placing colored stickies on them but they seem to leach all the
color out and then they goo poof also. What is one to do?
Old Apr 7, 2015 | 04:59 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Just a (too late) observation but I learned as a teen when I go into to something unfamiliar and there's more than one, I do it half at a time so I have a untouched origonal or a correctly assembled example to look at. Brakes are a good example, pull the tire off both sides of the same axle and do one side then the other. If you pull everything apart on both sides it's back to the manual and scratching your head if you hit a roadblock. I might pull all 8 injectors but I'd only pull 4 apart at a time.
Old Apr 7, 2015 | 05:46 PM
mustang_309's Avatar
mustang_309
See if this video helps,
Old Apr 7, 2015 | 08:31 PM
Yahiko's Avatar
Yahiko
0.5 nm = 70.80 in/oz
or 5.90 in/lb
Here is the handy tool.
Torque Conversion Calculator
Sean
jimbo1969
Jul 19, 2016 03:28 PM
Yahiko
May 13, 2016 06:45 AM
Yahiko
Jan 17, 2016 05:37 AM
Yahiko
Dec 30, 2014 05:12 PM
cleatus12r
Oct 21, 2004 06:51 PM
