Trans issues
Old Apr 5, 2015 | 10:09 AM
matthew polson's Avatar
matthew polson
Trans issues
ok iam new here but I need to reach out to find out what I have going on first off I have a 2000 f350 xlt and prior to the trans completely going out I was traveling through the mountains and when I was headed down the mountain I geared down the trans to help with breaking but the trans did not change gears it was as if I put the truck in neutral and free rolled so when I got off the mountain I pulled off i put the truck in 1st gear and took off again went thru all the gears everything worked no slipping few week later same deal down the mountain no gears when I geared the truck down when I got to the bottom of the mountain truck went on fine I hit a hill have truck a lil gas to maintain speed it down shifted and just reved out I let off gas it locked back into overdrive and kept pulling got to a stop light went to pull off truck wouldn't move it would begin to move and then just rev up does anyone have any idea what could cause this there is no trans noise rattling fluid is clean and not burnt I dropped pan not a lot of shavings on the magnet filer was not clogged if anyone has run into this before please let me know what you did to fix it the truck has 385k buy the trans is a reman was put in years ago
Thanks
Old Apr 5, 2015 | 10:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What needs to be done is to remove the trans and rebuild or replace it. The coast clutch has come apart.
Old Apr 5, 2015 | 11:12 AM
matthew polson
Trans issues
ok thanks that's good to kn
Old Apr 5, 2015 | 11:14 AM
matthew polson
TranS issue
ok that's good to know now would I just replace the coast clutch or would I have to get the entire transmission redone
Old Apr 5, 2015 | 12:52 PM
Mark Kovalsky
You can just fix the coast clutch if that's all that you find wrong when it's opened up. But the small additional cost to do the whole thing when it's out means most people do that, not just patch one problem.
Old Apr 5, 2015 | 01:52 PM
matthew polson
Trans issue
ok thanks for the info
Truxx1956
Dec 3, 2007 04:22 PM
butchoh
Aug 7, 2004 07:53 PM
Brown Beast
Mar 8, 2004 08:17 PM
92 Xplorer
Oct 4, 2002 04:29 PM
lr
Dec 27, 2000 09:36 PM
