Stalling issue
Old Apr 4, 2015 | 02:05 PM
goneinsixty's Avatar
goneinsixty
Stalling issue
I have '03 6.0 when it gets to full temp it will run horrible and eventually stall. It will take a few long cranks to restart. will drive a little bit but will stall again. It will idle all day long even after a stall. IPR @hot idle is 22 and ICP @hot idle is 640. IPR and IPC readings seem to run good throughout the rpm range except for when it dies. Then the IPR is anywhere from 71 to 85. Has new ICP and Pigtail. Runs very good until hot. I am leaning towards HPOP. Any input would be appreciated.
Old Apr 4, 2015 | 03:01 PM
BLADE35's Avatar
BLADE35
Those was my numbers when my hpop died
What are they at KOEO
Old Apr 4, 2015 | 03:08 PM
78fordman's Avatar
78fordman
Does the oil pressure gauge stay up? Do you have an oem oil filter and cap? A Lpo problem can seem like a hpo problem.
Old Apr 4, 2015 | 03:09 PM
BLADE35's Avatar
BLADE35
I tore it apart down to pump and it would let the reservoir drain they to the branch tube outlet in the pump
When I spun the hpop in my hand very rough
There were some good stuff in my thread search for it with my usser name
Old Apr 4, 2015 | 03:47 PM
goneinsixty
koeo... IPR14.8, IPC 29. IPR jumped to almost 80 when cranking to start cold. Just noticed now too that ficm output runs down as low as 44v when started cold. When warm ficm has been 47.5-48. ficm is probably starting to go but I don't think that is the issue. Blade, I will check out your info.
Old Apr 4, 2015 | 03:49 PM
goneinsixty
78fordman, Gauge does stay up but during start up it takes a few seconds to go up. Replaced the oil pressure sensor a few months back but didn't change anything.
Old Apr 4, 2015 | 03:54 PM
78fordman's Avatar
78fordman
That's normal. Watch the ect and eot, is it always about the same temp when it dies? This is sounds like a pump problem but they are an expensive part. I would set your scangauge to ipr, icp, icp desired and eot and go for a drive. If the ipr starts to shoot up and there is a difference in icp and icp desired with good base engine oil pressure upon increasing engine demand, it's your hpop. It will idle and hot restart all day, but can not maintain the icp pressure upon higher oil demand.
Old Apr 4, 2015 | 04:38 PM
goneinsixty
I don't see where I can set up to monitor ICP desired on my sg2? Am I just missing it
Old Apr 4, 2015 | 04:42 PM
78fordman's Avatar
78fordman
You will have to add it as a x gauge. Google icp desired x gauge and see if it comes up.
Old Apr 4, 2015 | 05:17 PM
goneinsixty
ok I will look. Thank You
Old Apr 4, 2015 | 06:55 PM
BLADE35's Avatar
BLADE35
ICPV AT KOEO SOORY MY BAD
But what is the FICM at when it runs bad
Your ficm is dying but your giving hpo symptoms
Your going to have 2 problems the ficm will die in next 6 months so better check into charge system after you get this hpo problem addressesd
IMO you current problem is hpo and should be fix first
Old Apr 4, 2015 | 07:17 PM
BLADE35's Avatar
BLADE35
My new pump runs 21.4% IPR
Old Apr 5, 2015 | 04:51 AM
goneinsixty
I tend to agree. I have also noticed that it dies more often than not going up hill or shortly after going up hill. I have had an issue for months of start stall 2 or 3 three times then runs when parked level or nose up. Maybe one has nothing to do with the other but I wonder. I am trying now to see if I can add ICP desired to my scan gauge 2 and check as 78fordman suggests.
Old Apr 5, 2015 | 09:18 AM
goneinsixty
A little more info... EOT at 211 deg. when truck stalls out. Oil pressure gauge stays up. Just prior to engine stall I hear what sounds like a whistling or whining. It sounds like a pump running empty or something. Maybe my pump grinding its self up! Max EOT that I saw was 221 deg. IPR goes to near 85 before stall.
Old Apr 5, 2015 | 09:21 AM
goneinsixty
ICP desired can not be loaded on my sg2
