Steering column
Old Apr 2, 2015 | 08:04 PM
trevisM's Avatar
trevisM
Steering column
Have several issues with my column and was wondering about interchange rather than rebuild.
Auto tran and factory cruise. Mine is tilt but that's not required.
Any sedan or van or such have a similar or same column?
All the trucks near me seem to have broke/worn out columns.
Old Apr 3, 2015 | 09:56 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
I think the van columns may fit, but they are longer. Would require some modification of the intermediate shaft. Remember, no welding on steering components!
Old Apr 3, 2015 | 10:27 AM
ctubutis's Avatar
ctubutis
1980 to the early 90s (1992? Whenever they started with that multifunction stalk thing) from F-series & Bronco will work as a drop-in replacement. Van columns, at a minimum, use a different turn signal switch and possibly different ignition lock cylinder stuff and wouldn't be a drop-in (no idea about length and whatnot).
Old Apr 3, 2015 | 01:42 PM
trevisM's Avatar
trevisM
Thanks for the reply, ct. Knew those would plug and play but had been told that some cars had same column with different dress.
Trouble is here trucks are used hard and never put away, so with all the crushing that has gone on over the last decade it's hard to find salvage parts. May have to do it the hard way and rebuild mine.
Old Apr 3, 2015 | 02:06 PM
trevisM's Avatar
trevisM
Not, I only do direct fit; why I asked "what if?"
70-360fe
Feb 6, 2013 06:03 AM
Rune007
Sep 23, 2012 03:38 PM
tbspks
Mar 21, 2006 01:49 PM
rmalottwtes30
Jul 30, 2005 10:14 PM
j.frank
Nov 5, 1999 12:47 PM
