1984 E350 steering column replacement
Old Sep 19, 2012 | 02:19 AM
Rune007's Avatar
Rune007
Hi All,
Got a 1984 E350 that has a steering column that is cracked due to previous owner using as a hoist go get into van. I found a used replacement online with 90 day warranty for $225 shipped. That seam reasonable?
Also my van is an auto w/o overdrive, but with tilt and cruse control, which I want to retain. Online parts place lists auto w/o overdrive, with tilt, but does not say anything one way or the other about cruse control. Does that matter? Or do I just need to transfer over the steering wheel and run the wiring down the new column?
Thanks
Drove down from Harts Pass WA over the weekend and freaked out I was going to break the column and plunge over a 1,000' cliff with the whole family on board! not going to do that again.
Old Sep 23, 2012 | 03:38 PM
fordman75's Avatar
fordman75
That seems a little expensive to me!! I usually get my steering columns for $50.00 or less.
I believe if your replacement column doesn't have cruise you'll have to swap over your steering wheel, turn signal switch and harness. I'm not 100% on the turn signal switch It's been close to a decade since I've had to tear into a van or truck steering column that age.
Stinkypete717
Jul 9, 2018 06:26 AM
JWA
1997 - 2003 F150
Sep 8, 2015 08:36 AM
rmalottwtes30
Jul 30, 2005 10:14 PM
j.frank
Nov 5, 1999 12:47 PM
