Knocking noise
Old Apr 13, 2015 | 11:33 AM
sunny.richter's Avatar
sunny.richter
Is this normal wear or is it something i should be worried about?
Old Apr 13, 2015 | 07:04 PM
Tugly's Avatar
Tugly
A: Get an OEM filter and cap.
B: Now I really suspect an internal oil leak.
You are a candidate for injector O-rings, but I still suggest the Cody test to confirm.
Old Apr 14, 2015 | 08:15 AM
sunny.richter
it wouldent smoke all the time if I had oil in my fuel? And be blueish? its definitely white smoke. Not blue at all and Only a little puff when I first start it
Old Apr 14, 2015 | 12:16 PM
Zeropowerstroke99's Avatar
Zeropowerstroke99
Well that's not my problem my fuel filter is clean
Old Apr 14, 2015 | 01:45 PM
Tugly's Avatar
Tugly
Injectors aren't high on the suspect list with yours. If it still knocks on decel, I'm leaning more toward valves or something more serious. Sorry.
Old Apr 14, 2015 | 02:00 PM
Tugly's Avatar
Tugly
That depends on the severity of the problem. Slightly loose injectors (50 - 75 inch/pounds torque on the injector bolts) will make all kinds of knock, lose some ICP, but not smoke too bad. A Cody test may reveal this, or you can just go in and check the torque. Checking the torque is a lot of work to do if you don't have O-rings on hand just in case. Does the knock go away on decel?
Old Apr 14, 2015 | 06:07 PM
sunny.richter
I tried to see on the way home after I read that. I didnt notice a lack of knock but this thing is pretty noisy. I gotta listen REAL close to identify it in the cab. Is it common to loose an O ring and not an injector? If im going to change em Id like to upgrade them and from my reading it seems you cant just upgrade one at a time. No sense in dumping a grand or two if nothings wrong. Ill be doing a cody test on my days off, thank you for the input. Im sure this is just coincidence but this all started after I cleaned my intercooler tubes. I checked for leaks and didnt find any just seems awfully strange. . . . Before I messed with the intercooler system I changed the glow plug relay and everything was great for about a month.. . .
Old Apr 14, 2015 | 06:08 PM
sunny.richter
also theres not much flat land around here at all to try the decel test on. . .
Old Apr 15, 2015 | 07:48 AM
Zeropowerstroke99
Looks like it's 12v time for me.
Old Apr 15, 2015 | 08:19 AM
Tugly's Avatar
Tugly
Decel is any time the wheels are pushing the engine, instead of the other way around. The injectors shut off with decel, so if the knock stops - the knock came from the sticks.
Bad O-rings on good injectors happen, but the frequency of just the O-rings going bad and the injectors are OK... well... not a good track record there.
Old Apr 17, 2015 | 01:10 PM
sunny.richter
got it plugged in to a machine. Says #8n cyl is acting up and you can clearly hear it on the passenger side. is this what I need? Alliant 'AE' Injector - Riffraff Diesel Performance
Old Apr 17, 2015 | 01:33 PM
The Brad's Avatar
The Brad
Number 8 is at the rear of the drivers side. It's very common for #8 to show an issue with a scan tool when non exists due to the firing order and fuel delivery.
Old Apr 17, 2015 | 02:17 PM
  #28
hotrodfeguy's Avatar
hotrodfeguy
My brother in law had this same issue. Looked at almost everything come to find out it was the flywheel the whole time. It was cracked. It would nearly go away at high RPM and come and go at certain RPM's. Most likely Harmonic. The crank bolts ended up getting trashed as well. So if it sounds like its in the bell housing it is something you may want to look at. You can get one of those scopes now real cheap at harbor freight.
Old Apr 17, 2015 | 06:02 PM
  #29
sunny.richter
hotrodfeguy, that has got to be the most discouraging thing I have heard yet. I feel a vibration on the floor board when im on the highway and cant find the source. The 'knocking' sound is clearly somewhere on the passengers side. You can barley hear it on the drivers. . . . Your freakin me out! Whats this scope you speak of? what codes did your brother in law get. Ive got
Intake air temp. sensor circuit high input
Cylinder 8 contribution/balance fault
ICP pressure above/below desired
Injector circuit/IDM codes detected
I was thinking about changing the IPR valve. . . Im gunna go revv it while its sitting and see if that vibration shows up.
Old Apr 17, 2015 | 06:29 PM
  #30
sunny.richter
no vibration a 2000 in park
