Knocking noise
Old Apr 17, 2015 | 06:54 PM
  #31
hotrodfeguy's Avatar
hotrodfeguy
He had no codes and that was almost exactly where it would go away 2k RPM. Also he had 4 cracks in it(we could see). When removing it fell apart !!! Not that that would make a guy feel better. Look on the harbor freight website for scopes they are like $100 with light on them and everything. Othewise it is hard to see cracks from the inspection hole. The light bulb went off in my head when you said it sounded like it was in the bell housing. My brother in law is using my trans jack right now he slid the trans back just enough to get a wrench on the bolts. Its not a whole removal job.
Old Apr 17, 2015 | 07:04 PM
  #32
sunny.richter's Avatar
sunny.richter
I can hear the knock better under the truck or in the wheel well than from above. Wouldent it be clearer from the top of the engine if it were and injector?
Old Apr 17, 2015 | 07:10 PM
  #33
sunny.richter
how often have you folks seen a spun crank or connecting rod bearing on these? Mine is a 2002 with 270k. All stock excep cone air filter and they cut the exhaust out and piced it together with that crappy exhaust flex
Old Apr 17, 2015 | 07:14 PM
  #34
sunny.richter
ill definitely check the fly wheel but after climbing under it and listening it seems to be low on the motor. Like a connecting rod bearing or something. It runs like a champ and only smokes or misses on startup. As soon as its warm NO issues what so ever and dosent do anything weird until the next day when its completely cold. Was his a standard?
Old Apr 17, 2015 | 07:16 PM
  #35
sunny.richter
oh im sorry, your comment was for Zeropowerstroke I accidently hijacked the thread.
Old Apr 26, 2015 | 09:58 AM
  #36
hotrodfeguy
As it was also sounding like it was in the bell housing area and sounded like a rod knock/steel crank issue. I wanted to show the results now that the job was finished. You could hear it from the top but it was clear as a bell from below. That's why we suspected it was not injector. We had even unplugged that #8 with no change in tone. Also as we had the VC off we unplugged each one at a time on that side, they all were working and pulling with no tone change in the bottom of the engine. It stumped us for a long time. But thank GOD it did not come totally apart of the highway.
http://i146.photobucket.com/albums/r...psh9wkuuhj.jpg
Old Apr 26, 2015 | 10:13 AM
  #37
sunny.richter
it didnt do anything weird when starting? No grinding noise or anything?
Old Apr 26, 2015 | 10:32 AM
  #38
mechelement's Avatar
mechelement
DAMN!!! Is that OEM? How many miles?
Old May 4, 2015 | 08:08 AM
  #39
hotrodfeguy
His had 220K
Sunny just said his was cracked as well. said he pulled it and pics to follow I guess.
Old May 4, 2015 | 08:27 AM
  #40
sunny.richter
sorry for the delay. Been working nights and trying to get this tranny cleaned back up an in. Here ya go. You cant see it until you completely pull it as the crack occur behind the spacer that attaches the flex plate to the crank.
Old May 4, 2015 | 07:32 PM
  #41
F350-6's Avatar
F350-6
Strange it's stamped E4OD. Is it stamped 4R100 somewhere too?
Old May 5, 2015 | 10:32 AM
  #42
hotrodfeguy
I think you found your noise LOL. I just wonder how many more are out there ???? Kind of like the X-files they are out there.
Old May 5, 2015 | 10:48 AM
  #43
sunny.richter
no its not. I thought that was strange too. It looks like something disastrous happened around the starter so maybe this was one the previous owner got out of a junk yard or something. The bell housing is real chewed up around the starter
Weston Gardipee
16
Jan 21, 2016 06:14 PM
Coresair
Jun 14, 2010 01:00 PM
F250TruckR
Apr 30, 2009 03:07 AM
John311t
46
Jul 17, 2008 11:42 PM
dijera
Jul 3, 2006 12:58 PM
