I have a few questions about a newly-acquired 66 F-100 Styleside long bed. First off, can you please decode the data plate info? Here's how it looks, in the order this info usually appears in (can't post photos yet): F10YK864023 129 M F100 E81 G 17 5000 172 4000 53 The other question involves a pair of clear, conical-shaped lights found on the ends of the bed sides (one each side) just under the tail lights. They don't look original to me; did these trucks ever come with back-up lights? I will appreciate any help you can give me on this.
F10 = F 100 2WD
Y = 352 V8 2v carburetor
K = Kansas City Assembly Plant
864023 = Assembled May '66 129 = 129 inch wheel base
M = Color code Wimbledon White
F100 = Conventional Cab, F-100 series
E = Trim code = Red crush vinyl and red cody pattern woven plastic
81 = Conventional Cab
G = Automatic transmission (COM only one offered)
17 = Ford rear axle, 3,300 lb capacity, 3.25 ratio 5000 = Maximum vehicle capacity
172 HP @ 4000 RPM
53 = District ordering the vehicle
Back-up lights first appeared in 1967. The 1961-1966 trucks didn't have them.
F10 = F100 2WD Y = 352 2V K = Kansas City MO Assembly Plant 864023 = 1966, Assembled May '66 129" Wheelbase M = Wimbledon White F100 2WD, 5,000 lbs. GVWR E81: E = Red crush vinyl and red cody pattern woven plastic / 81 = 81B Custom Cab. G = MX Cruise-O-Matic. 17 = Ford 9" rear axle / 3.25-1 / 3,300 lbs. Rear Axle Capacity. 5000 lbs. Gross Vehicle Weight Rating. 172 net HP @ 4000 RPM 53 = Kansas City MO Ford District Sales Office, where the original selling dealer orderedthe truck from.
