Hey all,
I tried searching first. Seems my electric vacuum pump 6C3Z-2A451-BA is worn out on my '99 7.3. Vac motor runs fine but diaphram doesn't pull strong enough. I pulled the pump intake tube off the reservoir tank (isolating the pump) and plugged it with my finger and it couldn't pull strong enough to engage the cutoff switch. When I put vacuum to the switch using a different vac pump, it switched off and on fine. So I'm guessing the seals in the piston/diaphram are worn? A couple questions:
1) Are these pumps rebuildable? It seems all I need is the diaphram seal but I haven't been able to find any info on rebuild kits or seals. The reason I ask is I see some of the aftermarkets are labeled "reman" so I figure they might be rebuidable.
2) If I am buying new, I've heard nightmares about aftermarket replacements of these pumps. Anyone had this? Anyone know of an aftermarket that is decent?
Hey all, I tried searching first. Seems my electric vacuum pump 6C3Z-2A451-BA is worn out on my '99 7.3. Vac motor runs fine but diaphram doesn't pull strong enough. I pulled the pump intake tube off the reservoir tank (isolating the pump) and plugged it with my finger and it couldn't pull strong enough to engage the cutoff switch. When I put vacuum to the switch using a different vac pump, it switched off and on fine. So I'm guessing the seals in the piston/diaphram are worn? A couple questions:
Thanks
Jeff
When you plugged the pump intake, did it stop? Then start again when the plug was moved? If that's the case, the pump would be working fine.
However, the Vacuum Pulse Module (VPM) may have an issue. Or, a leak somewhere in the circuit.
M-S-G
has your pump held up ok? how long you had it? is it loud? (just something I read)
thanks
I only had it for a year BUT it probably gets 5 years worth of usage during that time.
I have a medium vacuum leak that makes the pump on all the time.
To lazy to find it
Maybe someone will correct me but as long as you have hydroboost brakes the pump breaking is no big deal.
To lazy to find it
The pump breaking is no big deal unless you want to run your HVAC system on something other than defrost. The flapper that deflects the airflow to heat/panel/defrost works on vacuum and defaults to defrost in the event of a failure.
I replaced the vacuum pump & the 4x4 switch beside it as I was told of internal leaks causing problems , everything is working fine now , nice cold AC from my dash needed here in FL.
PROBLEM :the new pump never shuts off !!!
I have plugged both lines to the front hubs
plugged the line going to the dash , the only time the pump shuts off is if I put my finger over the suction on the pump , any ideas guys , pulling my hair out
You'll need to chase your leak one section of hose at a time. You have the pump shutting off there so that's a start. Run a piece of hose to the tank and plug the tank inlet. It might be the tank. Go from there.
