cab swap questions
Old Apr 19, 2015 | 04:11 PM
alchemist1's Avatar
alchemist1
The differences in electric:
1. 77 has fasten seat belt and brake for left and right instrument panel with high beam as a small light in middle. 74 has only brake light and high beam.
2. 77 has AC. 74 doesn't.
3. 74 has light package (cab, ash tray, glove cpmt., etc.). 77 doesn't.
Any issues perceived? Do I have to remove glass?
Old Apr 19, 2015 | 05:16 PM
bkaul's Avatar
bkaul
If it were me, I'd keep the cluster, A/C, and harness with the '77 cab when you swap it. For the light package you can use the '74 for parts if you want to add it to the '77 cab. Most of those (e.g. glove box light), there are already always-hot connection points behind the dash that you just plug into, whether the truck had the option installed or not; any extra wiring you need, you can scavenge from the '74.
Or if you don't want the A/C and you want to use the '74 cluster, use the wiring harness from the '74. Trying to modify one harness to work with the other cluster would likely be a bigger hassle than it's worth.
On glass, no idea. I haven't removed the cab from the frame on my truck - don't know if it would flex enough when moving it to crack the windshield or not. I'm sure others can chime in.
Old Apr 19, 2015 | 05:37 PM
lafermedavid's Avatar
lafermedavid
it will flex
BiltFordTuff
Feb 3, 2019 10:37 PM
jb10
Feb 21, 2010 10:03 PM
JKessler00
17
Jul 3, 2009 10:46 AM
fords_forlife
Oct 3, 2004 10:46 PM
