Reassembly advice
Old Jun 28, 2009 | 02:09 PM
JKessler00's Avatar
JKessler00
Reassembly advice
I got a different cab and I'm starting to rebuild my '79 F-250. I have a manual, and the cab I got was from an automatic. I'm not worried about that part. What I'm wondering is the heater core. I've attached two pictures of the difference between the two. Which is the better way to go? Is there an advantage from one to the other?
Old Jun 28, 2009 | 02:32 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
The cab in the 1st pic is a factory a/c cab, I think that big black box is the plenium?
Pic #2 is a NON a/c cab, do not mean to insult you, just wanted to make sure you knew that.
If you are going to go with factory a/c you will need the top pic cab or at least relocate the box, I believe.
I know a guy who removed his a/c system completely and I cut a none a/c cab patch to fill the hole, so he had the exact spot to bolt up his blower motor.
Hope this helps
Old Jun 28, 2009 | 03:51 PM
JKessler00's Avatar
JKessler00
The second cab will be replacing the cab in the first pic. I forgot about a/c. That's not an insult, I really didn't give that a thought. So it's better/easier to convert an a/c cab to a non a/c, rather than vice versa, correct?
Old Jun 28, 2009 | 04:05 PM
mark a.'s Avatar
mark a.
Either way it's a big deal. You would have to cut the firewall section out of the non ac cab and weld it into the cab that had ac & weld up a cupple of small holes too. I removed the ac from my cab, it was pia & now I wish I wouldn't have removed it to begin with.
Old Jun 28, 2009 | 06:07 PM
JKessler00's Avatar
JKessler00
Since there's room, can I just hook the heater hoses up and leave the a/c cab as is, though it won't actually have a/c?
Or I guess I could trace the outline of the hole in the firewall on the a/c cab, use that as a template, and cut out that portion on the old cab without the a/c. Then just weld that piece into the firewall on the new one. I want it to look good, but it won't be anything I'm going to go around bragging about.
Old Jun 28, 2009 | 06:25 PM
fmc400's Avatar
fmc400
MSEE
Im a little confused - you're using the non A/C cab, correct? Are you wanting to retain AC? Non-AC trucks have the heater hose fittings coming out of the firewall, whereas AC trucks have the heater hose fittings as part of the AC box. Also, on AC trucks there is a vacuum-operated shut-off valve inline with one of the heater hoses; it's not necessary for non-AC trucks.
Old Jun 28, 2009 | 06:59 PM
JKessler00's Avatar
JKessler00
No, I'm using an a/c cab. My current one does not have a/c and it is junk. I'm putting the cab with a/c on the non a/c truck.
Old Jun 28, 2009 | 09:34 PM
mark a.'s Avatar
mark a.
If you don't mind that big box left in there you can just leave it but I think you would have to hook some vacuum up to run the heater controls.
Old Jun 29, 2009 | 02:22 AM
77&79F250's Avatar
77&79F250
Keep in mind the a/c box is a space "eater" in the eng compartment, is you are not going to install a/c, I would remove the box. IMO
Cut the non a/c cab firewall area out and transfer it to the new cab. Its not that difficult, the box will make it a PITA If you are gonna run headers, changing spark plugs ect.....
Just my 75 cents
Old Jun 29, 2009 | 04:38 AM
peganit2's Avatar
peganit2
I'm doing the exact same thing. You don't have to weld the non ac panel in. It can be screwed, riveted or glued on.
There are duct, wiring and block off plate changes too. Don't get rid of the donor cab until your new cab is fully functioning.
Old Jun 30, 2009 | 01:51 AM
77&79F250's Avatar
77&79F250
Don't ask, I will gladly tell you.
Here is a example of a firewall patch job, with what ever was handy. Yes this is a friends truck, and yes he drove it to a FTE G2G like this and yes we picked on him ALOT.
He had to drive it there with no blower or heater core, just to get the correct patch panel I cut out for him out of another truck.
Old Jun 30, 2009 | 04:07 PM
ubereal2's Avatar
ubereal2
Look's like a fine patch job too. I'd bet that's still on that truck..... Bet he hasn't even put that other patch panle on................
Old Jun 30, 2009 | 06:02 PM
shanes66charger's Avatar
shanes66charger
why waste time to use the right patch when that one clearly works perfectly.
Old Jul 1, 2009 | 07:38 AM
77&79F250's Avatar
77&79F250
Yes its a very fine patch job, and yea I bet it's still on there, Unk Bob, LMAO. I am sure by winter "you" will to get the heater up and running.
Old Jul 1, 2009 | 07:41 AM
ubereal2's Avatar
ubereal2
Good point, sure hope you're right........... Need to get working on that, still haven't put my floor pan in I bought late last summer. Debating on sticking with the bench, or going to buckets, Usually it's just me and Tim in there...
