Sponsored by: Real Truck
column shifter lose?
Old Aug 27, 2010 | 07:11 PM
add2255's Avatar
add2255
my shifter has an awful lot of play in it does anyone know if there is some kind of adjustment or a way to fix this or just live with it?
Old Aug 27, 2010 | 08:51 PM
56Effie's Avatar
56Effie
On the bottom of your steering column, there are two torx bolts that work loose. They attach the bracket the shift cable snaps on, to the tube on the shifter column. I put lock tight on the bolts so they don't work loose again. Hope this helps.
Old Aug 27, 2010 | 11:44 PM
jc8825's Avatar
jc8825
Otherwise if it is not the bolts, you most likely need to replace the plastic bushings in the shifter line on top of the column.
Old Aug 28, 2010 | 09:47 AM
add2255's Avatar
add2255
thanks guys im going to go try and fix it now
Old Aug 28, 2010 | 12:02 PM
add2255's Avatar
add2255
ok it wasnt the torx screws lose so how do i replace that bushing?
bigreentruck
Oct 16, 2016 12:21 AM
GMbusa
Dec 14, 2015 11:42 AM
TJ62
Nov 29, 2014 11:23 PM
billest
Oct 24, 2013 08:28 PM
79-400-POWER
Offroad & 4x4
13
Jun 4, 2007 04:01 PM
