2001 Expedition with crazy electrical issues
Old Mar 30, 2015 | 10:16 AM
Frack's Avatar
Frack
After researching I have come to the conclusion that my windsheild seal may be leaking and causing my problems. (radio turning off/ on, power locks clicking up and down,washer fluid lighting up, abs lighting up and 4x4 lighting up) at random. I am thinking about resealing the windsheild and replacing the fuse block and GEM module. Are they difficult to replace? Do I need to have the GEM module reprogrammed in a 2001 if its used from the same make and model? Reprogrammed if its a new one? Thanks
Old Mar 30, 2015 | 12:09 PM
alloro's Avatar
alloro
I would start by just fixing the windshield. BTW, have a glass shop do it instead of trying to do it yourself. They have the experience to fix this problem right the first time. Once the windshield is fixed and the leak stops, the GEM will have time to dry out and your problems could go away. It's going to cost you $600+ to do the GEM and $200+ for the fuse box plus labor, and you might not need new ones.
Old Mar 31, 2015 | 07:14 AM
Frack's Avatar
Frack
After some time to dry in the garage with the battery disconnected the main electrical glitches have stopped. I am making an appointment to have the windshield looked at. However now my ABS light is on and stays on. Any thoughts? We disconnected the battery because you could hear clicking at the drivers side wheel well. I know thats where the fuses and Gem is located in the dash but is something else with brakes near there as well? Preparing for the worst hoping for the best!
Old Mar 31, 2015 | 10:37 AM
alloro's Avatar
alloro
It could be anything. If you get it scanned with an ABS capable scanner you'll know exactly where the problem is.
Old Mar 31, 2015 | 11:43 AM
projectSHO89's Avatar
projectSHO89
That is the ABS controller that's gone south.
Unplug it so it doesn't drain your battery until you can get it looked at.
Grss429
Oct 31, 2016 08:24 PM
stephsman30
Feb 25, 2015 07:25 AM
catfish4
1997 - 2003 F150
Aug 22, 2011 12:20 PM
nolapj
Jan 23, 2008 06:50 AM
ssrranger
Mar 29, 2004 06:48 PM
