GEM location and possible cause
Old Mar 28, 2004 | 09:36 PM
ssrranger's Avatar
ssrranger
Can anyone tell me where exactly I can locate the Gem Module in my 97 expedition? I had posted earlier that I am having gauge problems and wiper problems. Could it at all be related to the aftermarket radio I recently installed?
Old Mar 29, 2004 | 12:08 AM
buzzard's Avatar
buzzard
The GEM is located under the dash on the driver's side. It doesn't control the gauges, but does control the wipers.
Old Mar 29, 2004 | 07:21 AM
HomerWinzlow's Avatar
HomerWinzlow
The Gem is mounted to the top of the fuse box. The issue could be related to water leaks dripping down into both the Gem and fuse box and corroding/shorting circuits. A common problem. Many electrical anamylies can occur including instrument cluster, airbag system, abs, climate control, power accessories etc.
Old Mar 29, 2004 | 06:48 PM
FTE Herman's Avatar
FTE Herman
If you take it out, look for some form of corrosion on the metal parts. If it has been subject to a soaking you'll typically see mineral deposits or corrosion.
Trav402
6.7L Power Stroke Diesel
Mar 9, 2017 01:03 AM
plgebbia
Jul 26, 2011 06:00 PM
TX76F250
Dec 17, 2005 12:53 AM
germanbrave
Sep 15, 2005 12:25 PM
clay30
1997 - 2003 F150
Jan 14, 2003 09:17 AM
