Engine Help - I'm at a loss
Old Mar 28, 2015 | 08:06 PM
yourfavgui's Avatar
yourfavgui
Ford has been our vehicle of choice for 4 generations and may stop after this!
I need help I'll try to be brief.
Last month my 2005 expy 5.4L 108K miles started with all the classic signs of cam-phaser failure (rough idle, stalling, sounds like a diesel). I attempted every fix possible to no avail, I took it to our Ford dealer and they said low oil pressure has caused cylinder wall damage= NEW ENGINE. I bought a re-manned engine from a local shop with upgraded oil pump and ratcheting tentioners to avoid chain slap and new VVT solenoids. I installed it and have the exact same problems. I get a P0012 for bank 1 over retarded. I'm sooo angry that I've spent $4500 and nothing was fixed. I think there is a PCM issue or wiring problem. Please Please help.
Old Mar 30, 2015 | 10:06 AM
alloro's Avatar
alloro
Is it throwing any trouble codes?
Old Mar 30, 2015 | 09:51 PM
yourfavgui's Avatar
yourfavgui
I am currently getting P0012 for over retarded on bank one
Old Mar 30, 2015 | 11:52 PM
Skauber's Avatar
Skauber
Did you go back to those who sold you the engine and installed it? After spending that kind of cash, they should really be willing to help you in finding out what's the cause. Either a sensor issue or an internal issue in the new engine, and I assume that will be covered by the warranty on it.
Old Mar 31, 2015 | 10:30 AM
alloro's Avatar
alloro
Then I would suspect the (VCT) Variable Camshaft Timing Oil Control Solenoid. Assuming they swapped your existing one into the new engine. Note, the attachment only shows one, but there is a separate VCT for the left and right sides of the engine. You'll be looking at bank 1 which is the passenger side. You can also swap both of them to see if the problem moves to the driver's side.
File Type: pdf
Old Mar 31, 2015 | 11:43 AM
yourfavgui's Avatar
yourfavgui
Yes it does have a 36/mo, unlimited miles warranty, I put new CVT solenoids in already, I'll be heading back there for sure
Old Mar 31, 2015 | 11:46 AM
yourfavgui's Avatar
yourfavgui
Alloro Thank you for the diagrams. The new engine came with a different set (but used) VCT's. So I bought new ones and installed them, still runs like a diesel.
yourfavgui
Modular V8 (4.6L, 5.4L)
Sep 7, 2015 09:04 PM
keischeid
2004 - 2008 F150
Jun 21, 2010 01:52 PM
jsmile992000
2004 - 2008 F150
19
Jan 15, 2008 11:43 AM
John P
Aug 27, 2002 10:20 AM
mikes66
May 22, 2001 09:53 PM
