Computer Chips & Tuners
tuned EB
Old Mar 30, 2015 | 05:31 AM
user 708242442's Avatar
user 708242442
tuned EB
Just wondering how many of you are running a programmer in your EB? How's the fuel mileage and performance? I'm not looking to hit the track or anything, mostly looking for a little more as far as shifting and down low response.
Also what style are you running? Not sure which unit to go with, I do want a unit that allows to switch between tunes easily if needed.
thanks
Old Apr 1, 2015 | 08:29 PM
jaxf250's Avatar
jaxf250
Using a Livewire TS in my 2014 and have tried several tuners out there. Best one for me was SSI - truck is just a blast to drive, lots of power down low and great for traffic passing. I don't race - just want a great truck to drive. Shifting with SSI tunes is the smoothest of any tune I've tried and better than stock. Mileage is good and even a little better than stock if I can just keep my right foot off the fun pedal! Super easy to switch tunes with the Livewire - just need a PC at home (or Mac running bootcamp or parallels). SSI is working on the 2015 tunes - best to contact them for details for your truck. There is no better performance mod. for the money with these engines than a tune.
Old Apr 2, 2015 | 05:03 AM
user 708242442
What do you do if you need to go to the dealer? Is the unit easy to remove if needed?
Old Apr 2, 2015 | 06:51 AM
jaxf250's Avatar
jaxf250
The Livewire saves the stock tune, so you just flash back to stock (takes less than 10 minutes), unplug the tuner & head to the dealer. The unit does not need to be permanently mounted and has a single wire plugged into the diagnostic port under the steering wheel. Super easy to remove.
Old Apr 6, 2015 | 07:11 PM
user 708242442
ended up going with the x4
Dshanks86
Jan 30, 2013 08:28 AM
Jbru167
Apr 11, 2009 08:32 AM
txharley
Aug 30, 2007 01:25 PM
buckshot047
Mar 28, 2007 02:03 PM
Square Grouper
Sep 7, 2005 12:26 PM
