sticky ip
Old Mar 29, 2015 | 08:26 PM
bduemig's Avatar
bduemig
sticky ip
My truck is used strickly to pull my 5th wheel so it is usually in storage.
I replaced the ip 2 years ago. When I took it out of storage, it would stall when letting off the gas. I used the diesel clean in the filter method and it worked. It did the same thing this year.
2questions:
Does diesl sitting in the ip for a time gum it up?
If so, can diesel clean be left in the ip through the winter or could it damage seals in the ip?
Old Apr 15, 2015 | 09:40 AM
Chevy_Eater's Avatar
Chevy_Eater
It shouldn't, diesel fuel has a long shelf life before it gums up.
I doubt diesel kleen would hurt your seals, but if you're concerned just park it with ATF instead.
Old Apr 16, 2015 | 08:06 PM
bduemig's Avatar
bduemig
Never thought of ATF. Thanks for the suggestion.
TerryBarnard
Mar 21, 2017 11:36 AM
akamacgyver
Jun 22, 2012 01:09 PM
upnorthman
General Diesel Discussion
Jan 2, 2011 09:24 AM
Toreador_Diesel
Feb 22, 2005 04:10 PM
jchouck
16
Feb 20, 2003 10:58 PM
