Cutting out
Old Jul 25, 2003 | 11:21 AM
PCWest13's Avatar
PCWest13
Cutting out
I recently purchased a 1994 Ford F-150 XLT supercab. When I give it gas, it cuts out a bit. It is real jerky on acceleration. Do you think that it is just in need of a new fuel filter? I don't know much about cars because this is my first, so advice would be appreciated.
Also, I know these aren't fuel system related, but you might have some idea:
On my steering wheel, my horn, cruise control, and every other button do not work. What could be causing this and how do I go about fixing it?
My turn signals are slow. I have put in a new plug in for it, but it didnt fix anything. What is causing this and how do I fix it?
And last, is it possible to put dual exhaust on it?
Thank you!
Old Jul 25, 2003 | 01:23 PM
steve83's Avatar
steve83
Cutting out
For the hesitation, pull the codes.
For the horn, change the clock spring. look up how to here.
For the turn signals, change the round flasher in the underdash fuse block.
Old Jul 25, 2003 | 01:30 PM
PCWest13's Avatar
PCWest13
Cutting out
I did change the round flasher and it didnt change anything. And as for the site you gave me, I am really not educated in cars, so im not sure what that would be under. Think you might be able to help with that? Sorry.
Old Jul 25, 2003 | 06:02 PM
PCWest13's Avatar
PCWest13
Cutting out
Okay, im an idiot The first time I changed the wrong flasher. It worked. Now for the other problems....
Old Jul 26, 2003 | 12:30 AM
Ford_Six's Avatar
Ford_Six
Cutting out
Welcome to FTE!
For the hesitation, you may want to at least check the plugs and wires, possibly replace them if they look old. Repalcing the fuel filter is a good idea, too.
As for the steering wheel buttons problem, with everything not working, that is most definitely the clock spring. It may be listed under chassis electrical. If your truck has an airbag, don't do the repair yourself- you could wind up setting off the bag and injuring yourself. If not, remove the two or four screws on the backside of the steering wheel, remove the pad from the wheel, disconnect the plug, remove the steering wheel, remove and unplug the clock spring(plug may be further down on steering column), and install the new one. Make sure before beginning that the wheels are pointing straight ahead, and that you center the spring according to the manual. If you don't you will be doing the job again.
Old Jul 26, 2003 | 01:14 AM
LxMan1's Avatar
LxMan1
Cutting out
I would also check the TPS sensor for the hesitation. As well as the timing.
Jimmy
Old Jul 26, 2003 | 09:38 AM
PCWest13's Avatar
PCWest13
Cutting out
Sounds good. Thanks for all the help. This site is great, and saves mucho dinero on taking my truck to the shop. I now where I will come if I have further questions.
Thanks again!
Danieldorado
6.7L Power Stroke Diesel
30
Oct 5, 2016 01:47 PM
Grems4ever
29
May 30, 2015 05:51 PM
FlatHat Ranch
Mar 11, 2014 10:47 PM
Wicked Endings
13
Feb 9, 2011 07:04 PM
78fordman
Dec 4, 2003 10:09 PM
