78 cutting out
Old Dec 4, 2003 | 01:54 PM
78fordman's Avatar
78fordman
78 cutting out
I have a new edelbrock carb on my 78 F-100, and now it is cutting out. It is on a 76 390, and the carb is a 750 edelbrock with a manual choke. You can start it fine, and it will idle just fine, then you accelerate and get up to speed, about 1 minute after going down the road it will start to cut out, almost as if the fuel bowl emptys then it can not get any gas. When i put the carb, a guy told me that there is a fuel filter in there, like the stock for carb, but i found just a little screen. After the cutting out starts, i put a fuel filter on there, a little after the fact. Do you think this is in the carb, or in the pump. It can sit there and idle all day, but after about a minute from taking off, it will start to cut out. I have 3/8 line running from the pump to the carb, i had to replace that, but from my knowlegde, it was 3/8 which was on there. Should i take the carb apart and clean it? I am getting a fuel pressure gauge tonite, but what the pressure is supposed to be? I have adjusted the timing, and it does not help.
Old Dec 4, 2003 | 10:09 PM
LxMan1's Avatar
LxMan1
Fuel pressure should be around 5-6 lbs.
It could be vapor locking. Check the oil to make sure that the diaphram in the pump hasn't ruptured and it is pumping gas into the crankcase.
Jimmy
Kierobi
28
May 1, 2015 10:40 PM
Eighty_Six
Jul 6, 2014 06:32 AM
brokersteve
Dec 1, 2013 08:29 PM
cooktimj
Oct 7, 2013 07:12 AM
HighboyMac
Nov 10, 2006 11:00 PM
