one wheel locking up
Old Mar 28, 2015 | 08:30 PM
mike L's Avatar
mike L
My front wheel locks up on gravel. It doesn't do it on asphalt. I changed the caliper and shoes. I still have the problem. Any idea why this is happening?
Old Mar 28, 2015 | 08:33 PM
Tedster9's Avatar
Tedster9
Possibly brake hose?
Old Mar 28, 2015 | 08:53 PM
Conanski's Avatar
Conanski
You probably changed the wrong caliper. If your left front wheel is locking for example then it's the right front caliper that is not working properly.
Old Mar 30, 2015 | 01:55 AM
krooser's Avatar
krooser
We have a winner!
Old Apr 1, 2015 | 06:51 PM
mike L's Avatar
mike L
The right wheel locks up on dirt roads, when I slam on the brakes. Also does it during regular braking on loose gravel, like at a stop sign. I started by replacing that right caliper. Then I replaced the right brake line. Now I replaced the left side caliper, no difference. Would a bad brake line on the left side cause a locking wheel problem on the right side? It funny how it works fine on pavement.
Old Apr 2, 2015 | 12:42 PM
Phy's Avatar
Phy
If the left isn't working, you have to push the pedal harder, and end up locking up the right side.
On pavement, you probably have enough traction that it doesn't lock before you stop with 3 brakes.
I'd think, on pavement, that it'd pull to the right on hard stops...
Old Apr 2, 2015 | 03:05 PM
WoodBoss's Avatar
WoodBoss
If it locks up and doesn't release when you take your foot off the pedal it is probably the brake line. The inside of the brake line can collapse when it gets old and it will act like a check valve. It will let the caliper close but not bleed off the fluid pressure like a check valve effect.
Old Apr 2, 2015 | 03:20 PM
dixie460's Avatar
dixie460
Easy check. Jack the front end up and take off the wheels. Have a wrench handy that fits the caliper bleed screws. Get in the truck and start the engine so you have power boost, then mash the brake pedal down a couple times. Hop out and crack the bleeder at each side... if fluid squirts out under pressure you have a bad hose. If it just seeps out then your caliper is all jammed up.
Rick Rack
Aug 11, 2017 01:58 PM
Hawkline
1997 - 2003 F150
Mar 19, 2012 10:23 AM
bigtexan99
Dec 27, 2011 02:44 PM
rog2867
Jul 2, 2009 03:40 PM
mtong0001
2004 - 2008 F150
Mar 14, 2009 12:06 AM
