Vibration...
Old Mar 28, 2015 | 11:29 AM
Grems4ever's Avatar
Grems4ever
Vibration...
Well poo...
I've developed a pretty good vibration in the '87 from about 45-50 mph on up. It feels like a lean condition in the engine, but there's not many vibrations being transmitted though the gear shift. Here's what I suspect...
1. I know I have a loose lower ball joint on the driver's side. It may have worn enough to put up a vibration, but it doesn't seem to be in the steering.
2. Lean condition caused by failed O2 sensor. I need to check codes first...
3. Wheel(s) out of balance. Again, the vibration feels more general than specific to front/back or side/side but its possible.
4. Failed harmonic balancer - a real possibility since I haven't had any luck getting the timing marks to line up with the indicator to set the timing. I've never experienced what a failed balancer feels like to compare to.
5. EGR issue - disconnecting the EGR vacuum line and plugging the line improved performance from a dead stop, but still vibrated once at cruising speed.
I'm open to suggestions as I really want to get this back on the road without destroying anything else along the way.
Old Mar 28, 2015 | 12:07 PM
joey2fords's Avatar
joey2fords
get after what you know to be a problem first (ball joint). the next thing that i would suspect is wheel balance.
Old Mar 28, 2015 | 01:15 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ah all that you named and maybe a drive shaft u joint? Have you lubed the slip spline lately?
Swap tire positions (front to rear) and see if it moves....
Motor mount, trans mount, worse case (hope not) pinion bearing.
Old Mar 28, 2015 | 01:32 PM
Grems4ever's Avatar
Grems4ever
No slip spline on it. It mounts to the transmission similar to an automatic. The U-joints are new and recently lubed. The vibration was showing up prior to tearing it down so the rear isn't responsible.
I crawled under there and inspected the balancer. There are some tears in the rubber and a small amount of side to side play, but I wasn't able to find any rotational slip, but I didn't have the drivetrain locked down very well either.
I'll put a tire rotation on the list and see if that does any good.
I'm going to take back the power steering pump core and pulley tool. I'll grab a ball joint tool and the upper joint (already have lower) and change that out as well.
In the meantime, I'm reserving driving it for testing purposes until I figure it out. I don't want it to tear itself up for nothing.
Old Mar 28, 2015 | 01:37 PM
77&79F250's Avatar
77&79F250
Well good luck with it at least you can rule out all that stuff. I will stay in my lane and correct forum years from now on.....lol
Old Mar 28, 2015 | 01:40 PM
Grems4ever's Avatar
Grems4ever
Don't you dare Rich. I welcome all opinions about this. This vibration isn't like anything I've felt before...
Old Mar 28, 2015 | 01:46 PM
77&79F250's Avatar
77&79F250
Well ok, one more then, get the ball joint changed, ck the wheel bearing while you are there, rotate the tires and see if it moves.
Old Mar 28, 2015 | 02:32 PM
Grems4ever's Avatar
Grems4ever
<br />
<br />
That's the current plan. If that doesn't make any difference then I'll move on to something else.
I'll also check for codes to see if there's something amiss there as well.
Old Mar 28, 2015 | 05:06 PM
Grems4ever's Avatar
Grems4ever
Time for a dope slap and someone to shout "Well d'uh!"
I believe I found my vibration - I got the truck in position to work on the front ball joint and did a quick survey of my wheels. It appears that I have a rear tire without a single balance weight on it. I'm so embarrassed. I haven't driven a truck in so long that I forgot what it felt like to have a wheel out of balance...
Old Mar 29, 2015 | 05:54 PM
Grems4ever's Avatar
Grems4ever
I also suspect that I had a stuck u-joint as well. It still vibrated a bit after the wheel balance, but seemed to free up and run smooth as silk. After minimal use for the last year, I suspect even a new u-joint will get sticky. If it recurs, I'll pull the driveshaft and check them...
baarroyo98
2009 - 2014 F150
Jan 6, 2018 11:05 PM
mrmurph
Aug 8, 2014 02:04 PM
lance195
Nov 9, 2006 12:26 AM
Talyn
May 26, 2004 08:32 PM
