Sponsored by: Real Truck
70 km/h vibration
Old Nov 4, 2006 | 02:15 PM
lance195's Avatar
lance195
70 km/h vibration
Hi All
01 F350 4x4
I have a vibration that comes only at 39/43 mph. it feels like a tire so had them balanced, but it is still there. I crawled under and checked drive line and front "U" joints and found that the right front "u"joint is showing some wear would this be the problem? Regardless I will be changing it because it is worn. Let me know of any other troubles that anyone has experienced with this shaking. If it does not go away after the change out. I will repost my findings for all.
thanks Lance
Old Nov 7, 2006 | 01:16 PM
DavidWhittaker's Avatar
DavidWhittaker
The u joint should fix it.
Old Nov 9, 2006 | 12:26 AM
lance195's Avatar
lance195
well i have changed out the seized right front "u" joint and the vibration is still there . I thought for sure this was the problem since I could only move the "U" joint left and right and not up and down but this did fix the problem of not releasing from 4 wheel. So my next step is to have the driveshaft balanced and once again i will post my findings
Lance195
the78ranger
Jul 16, 2012 06:16 PM
Matt5
Oct 5, 2006 10:45 AM
hunter4427
Sep 29, 2006 08:20 AM
BowhunterKen
Offroad & 4x4
Dec 15, 2003 04:21 PM
